brake issues #319058
05/15/09 03:46 PM
05/15/09 03:46 PM
Anonymous OP
Anonymous OP
I installed a 383/727/8-3/4 rear with 11" brakes on rear factory disc on front in my 73 scamp. I am having problems with the brakes. I have new master cylinder, brake hardware, brake cyliners, pads etc. The only thing not replaced was the power brake booster. I have bleed the brakes twice, adjusted up the rear drums. the pedal feels fine until i start the car and then it goes way down. Any suggestions on what to check?
Re: brake issues #319059
05/15/09 04:06 PM
05/15/09 04:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You might need to adjust the rod that goes into the master cylinder to give you more pedal.
Re: brake issues [Re: stumpy] #319060
05/15/09 04:18 PM
05/15/09 04:18 PM
Anonymous OP
Anonymous OP
I will try that, do you think that the rod may not be going far enough into the cylinder and maybe not getting the fluid pressure into the lines during braking. The car will stop, but i am giving myself plenty of time right now.
Re: brake issues [Re: stumpy] #319061
05/15/09 04:47 PM
05/15/09 04:47 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Nor sure, but what I think Stumpy means is that you should remove the m/c from the booster. (If you can do it while the fluid lines are still attached, you won't have to rebleed the system.) Then, there is a rod that comes out of the center of the booster that is wht activates the piston in the m/c. I believe that rod is threaded and adjusts out/in so that there is minimal slop between booster pushrod and m/c piston recess for that rod. Don't adjust out too far, or m/c piston will not retract enough to replenish m/c cylinder as required when caliper pads wear and caliper pistons gradually travel out.
Re: brake issues [Re: MoparMarq] #319062
05/15/09 05:15 PM
05/15/09 05:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's what I meant but a lot less wordy. I figured if he could do all the replacing he did he would know how to adjust the rod.
Re: brake issues [Re: stumpy] #319063
05/15/09 05:20 PM
05/15/09 05:20 PM
If you know the rears are tight I think air still in there
Re: brake issues #319064
05/16/09 03:15 AM
05/16/09 03:15 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Sounds to me like you still have air in the system.
Re: brake issues [Re: Lefty] #319065
05/16/09 11:16 AM
05/16/09 11:16 AM
Anonymous OP
Anonymous OP
thanks all, i adjusted the rod a little and bleed the brakes for the 3rd time and all is well.
