Re: Need Recommendation for Barbeque Paint
[Re: Powerflow]
#3190546
11/12/23 11:01 PM
11/12/23 11:01 PM
Posts: 4,956 WI
Dcuda69
WI
I was cleaning up our barbecue before bringing it in for the winter and I noticed the paint on the sheet metal burner dividers has flaked away and the surfaces are rusty. I'm planning to refinish them this winter. What brands of spray-can high-heat paint have a nice gloss and decent durability?
TIA, Harold I am no help with your paint question but please tell me you don't stop using your grill in the winter. I'm in WI and I use my grill(s) all year long! I have a gas Weber and a Traeger pellet...one of them gets fired up at least twice a week all year long!!
[Re: TJP]
#3190597
11/13/23 12:10 PM
11/13/23 12:10 PM
Posts: 4,786 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I don't know if there are any barbeque paints offered in glossy. The heat turns any paint to an ash graphite flat color. Brush the metal free of flakes and corrosion. Clean it and paint it with any BBQ paint. Touch it up or redo it as needed. I did this with motorcycle 4 into 2 exhaust systems. Always had to redo the hottest spots as the paint doesn't last there.
Keep old mopars alive.
[Re: 2boltmain]
#3190720
11/13/23 10:50 PM
11/13/23 10:50 PM
Posts: 15,476 Omaha Ne
TJP
Omaha Ne
[Re: TJP]
#3190739
11/13/23 11:31 PM
11/13/23 11:31 PM
Posts: 21,528 N.E. OHIO, USA
A12
N.E. OHIO, USA
Also this POR 15 but seems it's only available in a flat finish. I know POR 15 sticks really well that's the real reason I used it on my 30-year-old mower deck top and bottom.......and you have to throw away the brush or applicator after use.
[Re: topside]
#3190796
11/14/23 11:38 AM
11/14/23 11:38 AM
Posts: 3,107 N.W. Florida
Fat_Mike
N.W. Florida
What about porcelainizing or enameling ? Kind of where my head is. Whatever Weber coats their kettle grills with lasts forever, but I believe that's porcelain. Not sure how to apply that...
[Re: Fat_Mike]
#3190820
11/14/23 01:00 PM
11/14/23 01:00 PM
A12
N.E. OHIO, USA
What about porcelainizing or enameling ? Kind of where my head is. Whatever Weber coats their kettle grills with lasts forever, but I believe that's porcelain. Not sure how to apply that... Don't know if this is the way it is done on a grill but I remember how it was done in school in a kiln at very high temperatures. Porcelain (/ˈpɔːrs(ə)lɪn/) is a ceramic material made by heating raw materials, generally including kaolinite, in a kiln to temperatures between 1,200 and 1,400 °C (2,200 and 2,600 °F). The greater strength and translucence of porcelain, relative to other types of pottery, arise mainly from vitrification and the formation of the mineral mullite within the body at these high temperatures. End applications include tableware, decorative ware such as figurines, and products in technology and industry such as electrical insulators and laboratory ware.
[Re: Powerflow]
#3190874
11/14/23 04:14 PM
11/14/23 04:14 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
PPG has a hi temp paint that does not burn off. Our shop we have a wood burner that is made out of 2 old air compressors. We sand blasted the tanks then sprayed this paint on it. Lets just say I can keep our shop warm enough even on a day when it is -20 outside here in South Dakota and we can work in short sleeves. It has been on there for a good 3 years or more. Not burned off. Does not smell when fire is rolling. I have had the fire rolling too. Our paint booth has been 85-90 degrees in the booth before when get a good fire rolling.
corey
Contact Me about AMD Prices
