Tuff Wheel Leather Restoration? #3160398
07/17/23 09:37 PM
07/17/23 09:37 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
I just got the red Tuff wheel that used to be in my 1981 Mirada (RIP) back at Carlisle after twelve years, and the outer grip needs to be re-done. I know it's cheaper to just buy one of the repops, but this wheel has meaning to me...and it's red, which matches the car it will go into. Does anybody restore these wheels?
Re: Tuff Wheel Leather Restoration? [Re: Remy-Z] #3161320
07/20/23 01:20 PM
07/20/23 01:20 PM
5thAve Offline
5thAve  Offline
I've found the odd local upholstery shops who do odd ball stuff like that. Did you try checking that yet.
I need to get mine done too but its the rubbery kind i just want to get it covered
Re: Tuff Wheel Leather Restoration? [Re: Remy-Z] #3161826
07/22/23 07:30 AM
07/22/23 07:30 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Tuff Wheel Leather Restoration? [Re: DAYCLONA] #3161838
07/22/23 09:00 AM
07/22/23 09:00 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I tried to come up with a alternative to the rubber but under it the rim is like 3/8-1/2 (don't remember exactly) the rest is foam rubber that is molded onto it. If the rubber is not deteriorated you probably can find a leather "cover" to go over it.
Re: Tuff Wheel Leather Restoration? [Re: DAYCLONA] #3164891
08/01/23 04:45 PM
08/01/23 04:45 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
I've reached out to them, look like they will be the choice. Thanks!
Re: Tuff Wheel Leather Restoration? [Re: Remy-Z] #3184900
10/18/23 06:21 PM
10/18/23 06:21 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
Thanks for the suggestion! Restored wheel came back today.
Re: Tuff Wheel Leather Restoration? [Re: Remy-Z] #3184901
10/18/23 06:21 PM
10/18/23 06:21 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
2
Re: Tuff Wheel Leather Restoration? [Re: Remy-Z] #3184902
10/18/23 06:23 PM
10/18/23 06:23 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
3
Re: Tuff Wheel Leather Restoration? [Re: Remy-Z] #3185592
10/21/23 09:25 PM
10/21/23 09:25 PM
5thAve Offline
5thAve  Offline
Cool! I was thinking of getting the one for my truck redone. Doing it in leather looks great.
Re: Tuff Wheel Leather Restoration? [Re: Remy-Z] #3190310
11/11/23 07:00 PM
11/11/23 07:00 PM
NYC
MARCH374 Offline
MARCH374  Offline
NYC
What did it cost ? Its looks great.
Re: Tuff Wheel Leather Restoration? [Re: MARCH374] #3190395
11/12/23 10:38 AM
11/12/23 10:38 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
What did it look like before? Did the rubber separate from the rod? When it does the rubber will "turn" on it. I have seen one of their replacement leather covers and they do look good! I would imagine they don't sell a do it yourself cover so you have to ship it to them.
Re: Tuff Wheel Leather Restoration? [Re: Moparite] #3190427
11/12/23 12:48 PM
11/12/23 12:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Can the ‘turning’ rubber be fixed? Mine for the Lil Red is that way.
Re: Tuff Wheel Leather Restoration? [Re: cudaman1969] #3190429
11/12/23 12:52 PM
11/12/23 12:52 PM
Kirkland, Washington
Pacnorthcuda Offline
I’ve never done it, but it seems the fix would be to inject glue (maybe superglue….wear eye protection!) with a syringe.
Re: Tuff Wheel Leather Restoration? [Re: Pacnorthcuda] #3190558
11/13/23 01:55 AM
11/13/23 01:55 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
I've successfully injected RTV using a syringe baster
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Tuff Wheel Leather Restoration? [Re: Pacnorthcuda] #3190742
11/13/23 11:49 PM
11/13/23 11:49 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
A friend of mine was doing this very thing (super glue ) back in the 80's..
on a couple Tuff wheels he had in his possession. It worked fine.
Plymouth Makes It!
Re: Tuff Wheel Leather Restoration? [Re: Hrtbkr] #3190809
11/14/23 12:31 PM
11/14/23 12:31 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Hrtbkr did mine also. Works great! Thanks Bill!
Re: Tuff Wheel Leather Restoration? [Re: 318 Stroker] #3200594
12/29/23 03:46 AM
12/29/23 03:46 AM
Canada
julianclar Offline
julianclar  Offline
Canada
I understand how important it is to restore something that holds sentimental value. If you're looking to restore the leather grip on your Tuff wheel, you could check out Von Baer. They offer leather products that might help with your restoration. Here's their website https://vonbaer.com/. You could also try reaching out to local car upholstery shops or leather repair experts for assistance. They might be able to restore the grip and even match the red color to your car.
