ODE TO THE HEMI ........... #3190356
11/12/23 12:44 AM
11/12/23 12:44 AM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
Re: ODE TO THE HEMI ........... [Re: kidmopar] #3190370
11/12/23 06:49 AM
11/12/23 06:49 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The technical analysis paper that started Chrysler engineers interest:
https://digital.library.unt.edu/ark:/67531/metadc54614/
A few Hemi shaped cylinder heads had been built previously,
inspired by the ideas that a hemisphere has less metal surface for heat to leak out of,
or the valves can be bigger:
https://en.wikipedia.org/wiki/Hemispherical_combustion_chamber
“Cross flow, canted valve”
turned out to be where the “goodness” lay
rather than the hemisphere.
I admire all the Mopar Hemi’s
because each represents progress.
The Nissan NAPS-Z tweaks to the Hemi deserve respect,
as Bob Lutz acknowledges.
Bob Lutz lured away two brothers who worked at GM who were frustrated with their bosses who would not let them design a cross flow canted valve cylinder head with squish and tumble concepts to promote faster burn which enabled less degrees of ignition advance. Less degrees of ignition advance mean less “negative work.”
If a cheap way to make hydrogen is developed
expect the cross flow, canted valve, engine cylinder head will be further developed.
Re: ODE TO THE HEMI ........... [Re: 360view] #3190394
11/12/23 10:26 AM
11/12/23 10:26 AM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
Its neat that the Hemi was a race engine first that was eventually and successfully adapted to a passenger car. All other engines were passenger car engines but used in racing. Fords attempt at this with their SOHC 427 just didn't work in its as offered state. The Ford 351 Cleveland 4BBL closed chamber heads I believe were race heads that soon after were adapted to passenger car use.
Keep old mopars alive.
Re: ODE TO THE HEMI ........... [Re: 2boltmain] #3190401
11/12/23 11:14 AM
11/12/23 11:14 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Wonder how history would have turned out if the ball stud hemi ever made it to production?
Re: ODE TO THE HEMI ........... [Re: Moparite] #3190601
11/13/23 12:31 PM
11/13/23 12:31 PM
Holland MI Ottawa
2
Holland MI Ottawa
I find this more interesting as time goes on. So I have learned, The Hemi head was superior on the dragstrip and oval but EXPENSIVE impractical overkill for a passenger car engine. The wedge head was a fantastic passenger car engine and great hot street performer- but didn't have potential to dominate racing. Along comes the Ball Stud Hemi. Canted valves though not better than the Hemi head design when going for all out racing were still very VERY good. So- not better than a hemi head BUT better than the inline c
valve wedge head. But the big bonus for Chrysler was the Ball stud used stamped steel rocker arms mounted on a rocker arm stud. Supe super inexpensive to make and reliable. Many aftermarket companies offer a Girdle for rocker arm stability when the RPMs and spring pressures begin to show the stud mount designs limitations. But the Mopars version of a 396 Chevy had a deep skirt B block that is incredibly strong where as the chevy has the crankshaft well below the oil pan mount surface. What could have been. I grew up having a confrontational rivalry with chevy guys- they were all arrogant, hated mopars and were loud mouthed. But The BBC is a force to be reckoned with- at least when it comes to building the engine into the big power High RPM stages. Tons of affordable aftermarket support to remedy any issues that arise during this journey and I imagine this rang true all the way back to the late 60s early 70s as well.
Re: ODE TO THE HEMI ........... [Re: kidmopar] #3191134
11/15/23 02:53 PM
11/15/23 02:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Still love the wedge engines, but The five gen 3s I have had, have all been good ones too. One with about 250,000 miles before I sold it.
Still preparing a proper home for my first gen 2 build.
Rich H.
Esse Quam Videri
Re: ODE TO THE HEMI ........... [Re: ZIPPY] #3191344
11/16/23 12:30 PM
11/16/23 12:30 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Agreed. I have built and owned both Gen II and Gen III Hemi's. I currently drive a 12' Challenger R/T Classic daily in Mi fair weather until the snow drops and it has been flawless. I like them both for different reasons. Nothing compares to the real Hemi though.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: ODE TO THE HEMI ........... [Re: 6PKRTSE] #3191568
11/17/23 10:48 AM
11/17/23 10:48 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Yeah, that’s impressive but I’m still partial to the early junk
Abe Lincoln
Re: ODE TO THE HEMI ........... [Re: dart4forte] #3191846
11/18/23 04:48 PM
11/18/23 04:48 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Can't beat the Hemi for eye candy in a engine bay!
