Motor plate with alternator #3189889
11/09/23 05:30 PM
11/09/23 05:30 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
I'm in the process of building my first car with a motor plate. I want to run an alternator as the car will see some street use. What are you using for an alternator and mount? Was looking at the AR engineering setup but it looks like the Doty crank pulley recommended is no longer available.
Re: Motor plate with alternator [Re: Racer33] #3189951
11/09/23 09:42 PM
11/09/23 09:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pulleys are pretty easy make. A decent sized alternator case is deeper than the front surface of the motor plate. I'm assuming a big block. That being said you'll have 3 choices. Mount the alternator below the plate. Cut a good sized hole in the plate for case clearance. Or mount it to the k frame. It can be forward or backward makes no difference. It's easier to mount on the passenger side do to the oil pump. If you are using a crank trigger and or vacuum pump all needs to be sorted out at the same time.
Doug
Re: Motor plate with alternator [Re: dvw] #3189958
11/09/23 10:07 PM
11/09/23 10:07 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
Doug
Pretty much exactly how I mounted all of my accessories.
Made most of my own FEAD.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Motor plate with alternator [Re: dvw] #3189970
11/09/23 11:10 PM
11/09/23 11:10 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Doug
Totally agree.
And I made my own pulleys. Setup is just a little different now because has a bigger alt.
Re: Motor plate with alternator [Re: Racer33] #3189979
11/10/23 12:13 AM
11/10/23 12:13 AM
AndyF Offline
AndyF  Offline
I probably have everything you need sitting in a box out in the shop. I have lots of pulleys and brackets that I've saved from various jobs over the years.
Re: Motor plate with alternator [Re: Racer33] #3190009
11/10/23 08:49 AM
11/10/23 08:49 AM
SWFL
Tie Rod Garage Offline
SWFL
I have several NOS Doty crank pulleys holding down a shelf. What one are you looking for ?
1941 Dodge WC, 493 cid twin turbo FAST XFI
2002 Dakota R/T RC
Re: Motor plate with alternator [Re: Tie Rod Garage] #3190011
11/10/23 08:54 AM
11/10/23 08:54 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
doty makes this set up which i got a few years ago.dont know if they make it anymore,ar engineering has mounts too
Re: Motor plate with alternator [Re: dart games] #3190054
11/10/23 01:27 PM
11/10/23 01:27 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Another option which I did on my old car, grab the Chevy bracket that mounts to the side on the block where the fuelpump attaches and use a turnbuckle to the framerail for tension
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Motor plate with alternator [Re: 67mprfan] #3190104
11/10/23 05:25 PM
11/10/23 05:25 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I used Andy’s alt mount with a 90 dodge truck alternator. Welded a tab to the frame rail for the tensioner. Looks like doty still has pullys on their website. ?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Motor plate with alternator [Re: Racer33] #3190146
11/10/23 09:16 PM
11/10/23 09:16 PM
AndyF Offline
AndyF  Offline
I have a Doty pulley if you still need one. I have a bunch of this stuff that I was going to put up for sale but haven't gotten around to it yet. Shoot me a PM if you want it. I can also sell you the AR Engineering parts at the same time if you want.
Re: Motor plate with alternator [Re: Racer33] #3190184
11/10/23 11:47 PM
11/10/23 11:47 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
Thanks guys. That gives me some ideas. Yes the car has a big block. I'm a former circle tracker who's heading down the straight and narrow now so I'm sure I'll asking for more help.
Re: Motor plate with alternator [Re: Racer33] #3190199
11/11/23 07:50 AM
11/11/23 07:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've been running the small alternator fpr 11 years. It can't keep up with the fans.This year giving it up for a real alternator. I'd start with a good sized one now.
Doug
Re: Motor plate with alternator [Re: dvw] #3190252
11/11/23 02:20 PM
11/11/23 02:20 PM
moparx Online content
moparx  Online Content
how many amps is the alternator you have now ?
what size are you going to ?
beer
Re: Motor plate with alternator [Re: moparx] #3190353
11/12/23 12:21 AM
11/12/23 12:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
beer
70 amp Denso mini. But the output is very low at idle (35 amp). Going to a Denso 118mm 150 amp that will put out 60 at idle.
Doug
Re: Motor plate with alternator [Re: dvw] #3190407
11/12/23 11:40 AM
11/12/23 11:40 AM
Motor City
Motor City
Mine is a East Coast 150 Amp and does just fine even on street all day with dual 2000 cfm (4000 cfm) fans, an Aeromotive 3000 fuel pump, and all lights on at night.
Re: Motor plate with alternator [Re: dvw] #3190428
11/12/23 12:50 PM
11/12/23 12:50 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
beer
Doug
I used a 55 amp East Coast alt for years. Finally saw the light and put a 120 amp East Coast alt in. What a difference! In summer heat car ran 20 degrees cooler when back to the pits because the pump and fan spun that much faster. Affinity laws at work........
Re: Motor plate with alternator [Re: markz528] #3190577
11/13/23 09:38 AM
11/13/23 09:38 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Just adding some ideas with two different engines I did. Definitely do it all on a stand BEFORE it goes in the car. In both cases for me, the best pulley placement put the back of the alternator slightly behind the back of the plate. In both cases I made my own tensioner brackets after establishing the pivot location. One, I hole-sawed the plate near its middle, the other I bolted the pivot near the bottom of the plate. Generally, I try to minimize any pulley offsets from there minimum potential positions.
