Re: Mopar breaking it off in customers for small parts!
[Re: 2boltmain]
#3190038
11/10/23 12:17 PM
11/10/23 12:17 PM
Posts: 4,683 Wichita
GY3
Wichita
Still absolutely ridiculous for the size of this thing! Especially when you consider how many of these were engines were made. It's not like it's a small, limited run.
[Re: GY3]
#3190039
11/10/23 12:26 PM
11/10/23 12:26 PM
Posts: 4,776 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Still absolutely ridiculous for the size of this thing! Especially when you consider how many of these were engines were made. It's not like it's a small, limited run. I agree. Its good the unit is easy to replace. Have you considered a different aftermarket brand? Not all chinese parts wre created Equally. Rock Auto has a good variety: https://www.rockauto.com/en/catalog/dodge,2009,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1443618,cooling+system,water+pump,2208
Keep old mopars alive.
[Re: 2boltmain]
#3190041
11/10/23 12:33 PM
11/10/23 12:33 PM
GY3
Wichita
Still absolutely ridiculous for the size of this thing! Especially when you consider how many of these were engines were made. It's not like it's a small, limited run. I agree. Its good the unit is easy to replace. Have you considered a different aftermarket brand? Not all chinese parts wre created Equally. Rock Auto has a good variety: https://www.rockauto.com/en/catalog/dodge,2009,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1443618,cooling+system,water+pump,2208 I bought an AC-Delco for $200 from a local supply house.
[Re: GY3]
#3190076
11/10/23 03:07 PM
11/10/23 03:07 PM
2boltmain
Holland MI Ottawa
Still absolutely ridiculous for the size of this thing! Especially when you consider how many of these were engines were made. It's not like it's a small, limited run. I agree. Its good the unit is easy to replace. Have you considered a different aftermarket brand? Not all chinese parts wre created Equally. Rock Auto has a good variety: https://www.rockauto.com/en/catalog/dodge,2009,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1443618,cooling+system,water+pump,2208 I bought an AC-Delco for $200 from a local supply house. Every DIYer should try RockAuto.com. They are a drop shipper that has negotiated fantastic prices on real name brand aftermarket and often OEM parts. An AC Delco water pump thru them for the 5.9 diesel Part number 252318 is $53.00. Shipping is probably $12-$15. No bootleg illegal counterfeit versions like what is often purchased off Amazon.
[Re: Sniper]
#3190166
11/10/23 10:47 PM
11/10/23 10:47 PM
Posts: 8,282 fredericksburg,va
cudaman1969
fredericksburg,va
It’s been about 4 years when my 06 Ram 4x4 shifting rod fell off (the whole thing gone) so off to dealer l, rod (about 14” long) was $130, the 2 bushing-connectors were $31 apiece. Almost $200 but I bought them. On a whim I looked on line ,yep there it was same thing $12 bushings $3.50 l, wholly crap! So I went back under the truck to remove the high dollar stuff, drop the plyers and lo and behold there lay the original ROD. Those stupid bushings had failed! Anyway the $ parts went back to dealer! I fixed the bushings with special clips instead! But $18 compared to $200 from dealer, same pieces!
[Re: GY3]
#3190176
11/10/23 11:25 PM
11/10/23 11:25 PM
Posts: 12,138 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'm sure most guys know that the majority of these kind of parts are not manufactured by the O.E. Heck, sometimes they are not even designed by the O.E. So, SOME (absolutely not all) aftermarket parts are as good (and a few even better) than the manufacturer's labeled parts.
The challenge is discovering which is and which is not at least as good as the O.E. labeled parts.
Master, again and still
[Re: cudaman1969]
#3190242
11/11/23 01:36 PM
11/11/23 01:36 PM
Posts: 6,277 nowhere
Sniper
nowhere
Have to agree somewhat on the factory prices, I had an 07 GT 500 Mustang that had aftermarket springs, it literally was sitting on the frame bumpers. So went to local Ford dealer to order new springs, they said I had to have the Vin number of car!? I had just looked at a King of the Road mustang in the showroom so I used that vin, thinking they would be expensive. Turns out each spring (4) were $31 each. Surprise Surprise, sometimes there is a deal. They did sit lower than stock but well off the bumpers. Who knows what the prior own might have done. I have put many aftermarket lowering springs in many cars over the years and none of them put the car on the bump stop. Someone heating coils with a torch to get it lower though....
[Re: Sniper]
#3190439
11/12/23 01:00 PM
11/12/23 01:00 PM
cudaman1969
fredericksburg,va
Have to agree somewhat on the factory prices, I had an 07 GT 500 Mustang that had aftermarket springs, it literally was sitting on the frame bumpers. So went to local Ford dealer to order new springs, they said I had to have the Vin number of car!? I had just looked at a King of the Road mustang in the showroom so I used that vin, thinking they would be expensive. Turns out each spring (4) were $31 each. Surprise Surprise, sometimes there is a deal. They did sit lower than stock but well off the bumpers. Who knows what the prior own might have done. I have put many aftermarket lowering springs in many cars over the years and none of them put the car on the bump stop. Someone heating coils with a torch to get it lower though.... Just springs no heat spots, I first made steel cup-spacers to raise off bumpers but front tires still laid in at top, no way to line up the front end correct. The springs were a good 8” in diameter. I think the dude wanted the NASCAR on the ground look. After buying car I was coming up 95 when I ran over a bad joint in road surface, the car literally changed lanes, glad nothing was beside me. It WAS fast, 525 hp to the wheels. Sweet sound from the supercharger!
