Re: Thermoquad
[Re: DEMONSIZZLER]
#319003
05/15/09 08:39 PM
05/15/09 08:39 PM
Posts: 757 Toronto, Ont, Canada
boydsdodge
Hi Demonsizzler, I was just wondering why you wouldn't post your answers about the ThermoQuad on here instead of PMing or Emailing? It would help other Thermo owners now and in the future. Thanks
Re: Thermoquad
[Re: boydsdodge]
#319004
05/15/09 10:34 PM
05/15/09 10:34 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Well ...I will post for all to see The chances are VERY GOOD that this prob is sunken floats. I will dig-up the brass floats # and post it later. The float issue on the TQ is very famous. Other than a MALadjusted secondary air-valve .... the problem caused by these bad floats are majorly complained about.
Re: Thermoquad
[Re: 6packattk]
#319006
05/16/09 05:15 AM
05/16/09 05:15 AM
dOoC
Florida STAYcation
I was looking for this topic before I hit-the-hay .... Most of the TQ's had "plastic" floats that did not need to be "old" to sink. Seems like some of the alky blend fuels did them in. ACC pumps ? .... I have done more than my share of the Plastic-Fantastics ....and honestly ...I have never had to need to replace one of those. ThermoBog ? ... ... you calling it that - you STILL could not have figured that AV out. ALL you need is that new-and-improved AV tool to tweak-it-right. Available from yurrs-truly ! Join the ThermoSquad ....and Blast-da-Bumz !
Re: Thermoquad
[Re: gdonovan]
#319009
05/16/09 09:26 AM
05/16/09 09:26 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
If the gas is on the top O ring or jet wells leaking probably won't be the problem.
Another thing to check is the float level. That is measured WITH THE GASKET INSTALLED! So you may have them set too high.
Rug_Trucker SFC. Mid TN Thermosquad
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Thermoquad Flooding. Floats? needle/seats?
[Re: 68Bullit]
#319010
05/16/09 10:20 AM
05/16/09 10:20 AM
RapidRobert
I'd put a good filter ahead of the carb and a new needle/seat
[Re: 68Bullit]
#319013
06/07/09 11:15 PM
06/07/09 11:15 PM
RapidRobert
that is a stock(airtex type I believe) pump. got a vacuum gauge handy w the neoprene adapter to fit it to your fuel line as most have a psi scale to use also but I will opinionate that excessive psi is not the problem.
