Running/built 440 & 727 value
#3188388
11/03/23 12:09 AM
11/03/23 12:09 AM
Posts: 1,008 Central US
grancuda
Central US
Thinking about changing drivetrain & selling the 440 & 727. Just curious ball park what I should expect to be able to get out of my current set-up.
‘71 440 .060 over Edelbrock Performer RPM heads 84cc Forged Domed TRW pistons Balanced rotating assy w/steel crank Comp Solid flat tappet XS282S Crane gold roller rockers Weiand X-celerator Ported/Polished single plane intake Aluminum water pump housing High volume pump
727 with CRT reverse manual valbe body 3500 TCI stall converter
Fresh cam, heads, comp springs with around 250 miles Unsure miles on bottom end 1,500 miles on the 727 set-up
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: Running/built 440 & 727 value
[Re: 6bblFLASH]
#3189881
11/09/23 04:34 PM
11/09/23 04:34 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I'd agree it's a $6K setup running. $7K might take a bit more time to find a buyer.
Lead, follow or get the hell out of the way
[Re: dart games]
#3189967
11/09/23 11:06 PM
11/09/23 11:06 PM
grancuda
Central US
It’s not an HP block
Tulsa OK
