Re: Looking to find a good, home mechanic type scan tool
[Re: StrokerPost]
#3188615
11/03/23 09:35 PM
11/03/23 09:35 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
I just bought a Fixd - but have not tried it yet. Still need to download the app. Seemed like this was a pretty well-rated device. Can anyone confirm this?
[Re: StrokerPost]
#3188645
11/03/23 11:06 PM
11/03/23 11:06 PM
Posts: 12,150 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We have used the Autel scan tools for several years now. They have a full line, are available on Ebag and Amazon, have free updates, and start at about $20. Of course you can spend $1,500+ for one if you want to...................
Lots of choices, depending on how much you want to do. I would recommend one that would be able to do OBDII and ABS. A TPMS scan tool is handy now a days, too.
Master, again and still
[Re: DaveRS23]
#3188647
11/03/23 11:26 PM
11/03/23 11:26 PM
Posts: 1,220 Nor here, Nor there
Dart 500
Nor here, Nor there
Autel MaxiLink ML619 CAN OBD2 Scanner Code Reader +ABS/SRS Diagnostic Scan Tool
The cheap ones run simple codes, but you need one that explains ALL codes . Air bags, traction control etc.
[Re: Dart 500]
#3188663
11/04/23 05:54 AM
11/04/23 05:54 AM
Posts: 5,850 ohio
ruderunner
ohio
Secondhand outdated scanners are cheap on the tool trucks. Most are more powerful than any home mechanic needs.
Just need to know what years the programming does and what years the vehicles are.
Angry white pureblood male
[Re: ruderunner]
#3188680
11/04/23 09:45 AM
11/04/23 09:45 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Before making a decision on used 'tool truck' scan tools, be SURE to ask about the need and cost of updates.
[Re: DaveRS23]
#3188710
11/04/23 12:15 PM
11/04/23 12:15 PM
Posts: 6,281 nowhere
Sniper
nowhere
really depends on what you are working on. For my BMW I use Bimmerlink, only thing I got with a computer. For Mopars AlfaOBD has great reviews, 1994-2023 coverage https://www.alfaobd.com/"The AlfaOBD features include: monitoring various dynamic parameters of engine, transmission, body, dash, ABS, climate control, etc., and graphical presentation as adjustable plots reading of the static data: ECU id, system status, fault codes (DTC) with probable causes and environment information (freeze frames) where applicable clearing of fault (DTC) codes, monitoring the system for the occurence of new faults active diagnostics and configuration procedures for various equipment controlled by the ECUs. Service light reset, engine oil change, DPF regeneration, ABS bleed, air suspension maintenance, transmission calibration procedures, and many more. electronic key and RF remote control programming on some vehicle models adjustment of the car configuration with the ability to activate the newly installed equipment in the Body computer configuration, the Proxy alignment." Uses the same OBD dongle my Bimmerlink does If you wants some universal covers every thing option, I have used these guys https://www.innova.com/pages/repairsolutions2-app
[Re: Sniper]
#3188747
11/04/23 03:03 PM
11/04/23 03:03 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I searched for years and could not figure out what to buy. So about a year ago I bought a Zurich Pro from harbor freight for $800. They don't make them new anymore, but they seem to have a bunch of them reconditioned. The bad part is there is very little to no support. The good news is it has a ton of capability for the money. If I bought an Autel with the same capability I would of paid several times more. It seems to be perfect for my home shop use. https://www.harborfreight.com/zr-pr...scanner-factory-reconditioned-57917.html
[Re: markz528]
#3188865
11/05/23 10:19 AM
11/05/23 10:19 AM
Posts: 1,083 Long Island, NY
70plymA34
Long Island, NY
get one with a 2 channel scope integrated into the software. The scope function is definitely a help with the diagnostic process instead of throwing the parts cannon at your vehicle.
Super Commando
[Re: Dcuda69]
#3188940
11/05/23 04:29 PM
11/05/23 04:29 PM
Posts: 5,850 ohio
ruderunner
ohio
Same applies to most any "OBd2" scanner Limited access and no datastrem
How deep does a hobbyist get?
I picked up an ancient OTC Monitor 400 to work on my pre OBD2 stuff, 100 bucks. Obsolete and no upgrades available. Currently I also have a Bosch Mastertech, last updated 2010. Works on everything we need but obviously not fully functional on newer stuff. It can be updated but why?
