Bringing a Dash pad back from the dead #3187945
10/31/23 10:13 PM
10/31/23 10:13 PM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
I got lucky and scored a crack-less 1971-74 B-body dash pad in green! I had to buy the whole car to get it (trashed) but it was worth it.
Even though it has no cracks it's very dry. I've tried several products that are supposed to condition vinyl and leather; Mequire's, Mother's and Vinylex, they just absorb into the vinyl like a spouge. Anybody have any tricks to moisturizing/conditioning vinyl?
No longer taking $h!t from anyone!
Re: Bringing a Dash pad back from the dead [Re: DUFFMAN] #3187971
11/01/23 06:48 AM
11/01/23 06:48 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve used petroleum jelly (Vaseline) on my 70 Cuda per a friend of mine in the upholstery business.. he said never to use Armor All because it would destroy the material under the top vinyl. It stays on longer. Let it set for a few days then wipe off the excess. My pad has stayed perfect all these years.
Re: Bringing a Dash pad back from the dead [Re: fastmark] #3188184
11/02/23 02:33 AM
11/02/23 02:33 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Go to You Tube. Search for "sweet project cars restore old vinyl".
Re: Bringing a Dash pad back from the dead [Re: DUFFMAN] #3188242
11/02/23 11:13 AM
11/02/23 11:13 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I don't think it can be rejuvenated after all the decades exposed to UV rays. Once installed it should be safe from any impact or things that would damage it. If you apply a rejuvenating product I believe you'd want to re apply that product on a regular basis for the rest of its life.
Keep old mopars alive.
Re: Bringing a Dash pad back from the dead [Re: 2boltmain] #3188252
11/02/23 11:55 AM
11/02/23 11:55 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Never had any success with renewing dryed/ hardened dash pads. It seems like once it is gone it`s gone but it is always worth a try.
Re: Bringing a Dash pad back from the dead [Re: mopars4ever] #3188400
11/03/23 03:17 AM
11/03/23 03:17 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I’m agree it won’t get really completely rejuvenated but just a bit better. Or at least save it from get it worst.
Re: Bringing a Dash pad back from the dead [Re: fastmark] #3189455
11/07/23 06:55 PM
11/07/23 06:55 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I covered it with vaseline for a day and it seems to have worked pretty good. The vinyl is mostly shiny again. I'll have to try leaving it on longer and see what happens.
Re: Bringing a Dash pad back from the dead [Re: DUFFMAN] #3189461
11/07/23 07:30 PM
11/07/23 07:30 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Internet says products with petroleum distillates can be harmful to some rubber and vinyls
Have not tried it, but brake assembly lube, aka Syl Glide, might work? People use it on rubber weather-striping, etc. all the time.
Re: Bringing a Dash pad back from the dead [Re: Neil] #3189462
11/07/23 07:37 PM
11/07/23 07:37 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have used ATF with good results for 25 years does not leave it greasy. just use a tiny bit on a cloth
Re: Bringing a Dash pad back from the dead [Re: chrisf] #3189515
11/07/23 10:15 PM
11/07/23 10:15 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I assume you're talking about Mercon/Dextron? I'd be concerned about what the additives in more modern ATFs like ATF+4 or ZF fluid might do.
