Harmonic balancer speedi sleeves #3187526
10/29/23 11:36 PM
10/29/23 11:36 PM
Eagle, Idaho
Neil Offline OP
The Doctor is in.
Neil  Offline OP
The Doctor is in.
Eagle, Idaho
We all know about these, and how they are used to help save a worn damper with a groove from high miles. If your putting together a daily driver engine that is going to see a lot of miles, or using an expensive damper would it not make sense to install a speedi sleeve on the new balancer right at the start? Never seen anyone do this on a new engine build, and yet it seems like it would have no drawbacks? SS is harder than cast steel or cast iron that most balancers are made of so it should last much longer or maybe even forever? Anyone ever wear out a speedi sleeve before?
Re: Harmonic balancer speedi sleeves [Re: Neil] #3187538
10/30/23 04:42 AM
10/30/23 04:42 AM
birdtracker Offline
birdtracker  Offline
on semi trucks that get thousands of miles. Birdtracker
Re: Harmonic balancer speedi sleeves [Re: Neil] #3187567
10/30/23 09:33 AM
10/30/23 09:33 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
It takes a long time and lot of miles to wear a groove in a balancer, plus depending on what brand seal you are using, most replacements are made with the seal lip in a slightly different location. I have seen old balancers with two or three grooves in them. No issues with a stainless-steel sleeve I would think a little overkill on a new balancer.
Re: Harmonic balancer speedi sleeves [Re: jwb123] #3187577
10/30/23 10:14 AM
10/30/23 10:14 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Maybe I'm misunderstanding what I am seeing but I'd swear that a sleeve on a balancer wears a groove faster than the balancer itself.
Re: Harmonic balancer speedi sleeves [Re: 6PakBee] #3187665
10/30/23 03:32 PM
10/30/23 03:32 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
This is true. I put a bunch of speedy sleeves on Allison output yokes and they eventually wear a groove in the sleeve and leak.
Re: Harmonic balancer speedi sleeves [Re: rickraw] #3187668
10/30/23 03:40 PM
10/30/23 03:40 PM
Eagle, Idaho
Neil Offline OP
The Doctor is in.
Neil  Offline OP
The Doctor is in.
Eagle, Idaho
Wonder if that is due to the larger diameter of the sleeve making the seal fit tighter so it increases the amount of friction? I've never installed one of these and was just curious if this was a good idea or not to use one right off the bat.
Re: Harmonic balancer speedi sleeves [Re: Neil] #3187731
10/30/23 09:14 PM
10/30/23 09:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Larger diameter does increase friction, plus dirty oil causes wear. If you can find one give a shot, just use a fine point pick to get the seal lip over the edge of the sleeve or it will get cut.
Re: Harmonic balancer speedi sleeves [Re: rickraw] #3187832
10/31/23 12:06 PM
10/31/23 12:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a damper from Damper Doctors that came back with a sleeve on it. I've had it on a couple motors and there's no wear on the sleeve yet, but it's drag race only.
Re: Harmonic balancer speedi sleeves [Re: Neil] #3187847
10/31/23 01:00 PM
10/31/23 01:00 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I'm sure cast iron is harder than stainless, and has better wear properties.
Re: Harmonic balancer speedi sleeves [Re: 375inStroke] #3187852
10/31/23 01:27 PM
10/31/23 01:27 PM
moparx Offline
moparx  Offline
it all depends on the grade of stainless or cast iron the item is made out of.
having machined all grades of both over my 45+ working career, i have run into cast iron that was so hard it was a real task to find the right cutting insert grade to plow through it.
and although stainless grades can be super tough as well, i have cut several grades of it as though it was made of butter.
just my personal life experiences as a machinist. your mileage will vary.
beer
Re: Harmonic balancer speedi sleeves [Re: Neil] #3188336
11/02/23 06:28 PM
11/02/23 06:28 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
speedy sleeves are soft. If they were hard they would split when being stretched onto the parent part. If you had cast material as thin as a speedy sleeve, it would split as soon as you started to press it on.
Re: Harmonic balancer speedi sleeves [Re: TRENDZ] #3188398
11/03/23 02:31 AM
11/03/23 02:31 AM
I've used 4 or more speedy sleeves on several different Mopars brands motors and the other brands engines from NAPA and Auto Zone parts stores and had no issues with either brand up
I lube up the seal and balancer snout with H.D black moly wheel bearing grease up
I use Anti seize on the snout of the crankshaft and the inside sealing surface of the balancer also wrench up scope
Re: Harmonic balancer speedi sleeves [Re: Cab_Burge] #3188486
11/03/23 01:40 PM
11/03/23 01:40 PM
Eagle, Idaho
Neil Offline OP
The Doctor is in.
Neil  Offline OP
The Doctor is in.
Eagle, Idaho
Yes, it's good to lube those up so the new seals don't run on dry metal on the first start. I use assembly lube and also put it on transmission front pump seals where the convertor goes in too. Just a light coat does the job.
