Hydraulic roller lifters and RPMs #318834
05/15/09 11:18 AM
05/15/09 11:18 AM
Baltimore, MD
3
397STROKER Offline OP
super street
super street
3
Baltimore, MD
Is there any trouble running the hydraulic roller lifters in a magnum engine to 6500 rpms? Will they work ok or should you be looking at after market lifters?
Re: Hydraulic roller lifters and RPMs [Re: 397STROKER] #318835
05/15/09 12:32 PM
05/15/09 12:32 PM
scratchnfotraction Offline
if the springs match the roller cam should be no problem at higher rpms
magnum stock springs wont cut it
I run my lunati roller with comp 901-16 springs and have been 6200 with no float with stock roller lifters,PR,stamped rocker
cam was nosing over after 5500 but no float at 6200
and they got well over 150,000 miles on them from a jy engine,when I swaped them in in 06
Re: Hydraulic roller lifters and RPMs [Re: scratchnfotraction] #318836
05/15/09 12:52 PM
05/15/09 12:52 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
IIRC Jesse Lackman has had them up near 7k without problems. it all depends on valve springs and valvetrain weight (a stock magnum 1.92 dia, 8mm stem is MUCH lighter than an LA 2.02 dia, 3/8 stem valve, stock rockers are much lighter than ductile iron, etc)
2017 Grand Cherokee Overland
