1970 Cuda Power Window Question #3188238
11/02/23 10:39 AM
11/02/23 10:39 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi Everyone,
Working on a 70 Cuda with power windows for the first time. Biggest issue is the passenger
door. The window seems to come down fine, but going up from all the way down it stops
about 1" up. It seems to bind up, I give it a little pull and it will go, but very slowly. I greased
the runners and rollers, no luck.
Is there a particular adjustment I should be looking at?
Thanks in advance,
Re: 1970 Cuda Power Window Question [Re: jim6346] #3188299
11/02/23 03:53 PM
11/02/23 03:53 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Do you have "new" cat whiskers ??? Seems many are "tight" on the windows . . .
Re: 1970 Cuda Power Window Question [Re: jim6346] #3188366
11/02/23 09:31 PM
11/02/23 09:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Is the lift spring on the regulator in place and not broken?
Re: 1970 Cuda Power Window Question [Re: TJP] #3188413
11/03/23 06:28 AM
11/03/23 06:28 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi TJP,
I will look, but don't remember seeing a spring. Where would it be located?
Thanks!
Re: 1970 Cuda Power Window Question [Re: jim6346] #3188434
11/03/23 09:45 AM
11/03/23 09:45 AM
Canada
E
EW1BH27 Online content
EW1BH27  Online Content
E
Canada
Not having a PW car I'm thinking this is the "lift spring". Please correct me if I'm wrong.
Re: 1970 Cuda Power Window Question [Re: EW1BH27] #3188484
11/03/23 01:28 PM
11/03/23 01:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You are correct sir. The reason for it is the weight of the window itself. It is no needed so much coming down for the same reason it is going up, IE: the weight of the window helps wind the spring coming down and the tension of the spring helps when raising the window beer
Re: 1970 Cuda Power Window Question [Re: TJP] #3188886
11/05/23 11:34 AM
11/05/23 11:34 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Thanks everyone, turning into a big project frown
Another problem, I have the rear quarter glass lined up nice, but it goes up about 1/4" too far, I don't see any
upper bump stops anywhere. Is there an adjustment for this?
Thanks!
Re: 1970 Cuda Power Window Question [Re: jim6346] #3188973
11/05/23 06:51 PM
11/05/23 06:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You need a factory service manual wink
Re: 1970 Cuda Power Window Question [Re: TJP] #3189010
11/05/23 09:17 PM
11/05/23 09:17 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Yeap: that would have addressed all the questions here.
Geez: most are online these days, not like you have to buy one.
