Comps Hydraulic rollers #318813
05/15/09 11:09 AM
05/15/09 11:09 AM
Baltimore, MD
3
397STROKER Offline OP
super street
super street
3
Baltimore, MD
Do CompCams Hydraulic roller cams require a bronz gear?
Re: Comps Hydraulic rollers [Re: 397STROKER] #318814
05/15/09 11:15 AM
05/15/09 11:15 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
That all depends on if its a billet core cam, or not, If its not, then no, if it is, yes. You will have to ask them as some I have installed have been either way.
Re: Comps Hydraulic rollers [Re: Moparnut426] #318815
05/15/09 11:41 AM
05/15/09 11:41 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I went with one of their 'retro' hydraulic rollers in my 440 and it was a steel billet cam and accordingly required a bronze gear. I also went with a 'torrington' style cam gear as well as a Comp rollerized cam button. So far, so good!
Re: Comps Hydraulic rollers [Re: 397STROKER] #318816
05/15/09 11:46 AM
05/15/09 11:46 AM
Baltimore, MD
3
super street
super street
3
Baltimore, MD
I understand the billet steel thing but I know that Crane used to make their retro Hydraulic rollers so you didn't need a bronz gear. Just was wondering if Comp did the same as Crane is gone.
Re: Comps Hydraulic rollers [Re: 397STROKER] #318817
05/15/09 11:49 AM
05/15/09 11:49 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Yes Crane had retrofit roller cams that did not require a bronze gear. I have a Comp Cams retrofit roller in mine and it requires a bronze gear.
Re: Comps Hydraulic rollers [Re: 69Cuda340S] #318818
05/15/09 12:26 PM
05/15/09 12:26 PM
scratchnfotraction Offline
my lunait roller has a pressed on iron gear and does not need the bronze gear
some do,some dont,ask Mfg for info on the cam you select
