Re: Remanufactured Engine?
[Re: poorboy]
#3187959
10/31/23 11:13 PM
10/31/23 11:13 PM
Posts: 10,736 North Dakota
6PakBee
North Dakota
I just helped a Bud replace the engine in his Saturn mini-van. He got a reman long block from NAPA.
[Re: 6PakBee]
#3188017
11/01/23 11:30 AM
11/01/23 11:30 AM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
Thank you all. This definitely gives me some more options. If could pull it off, I would buy a running driving truck but, I'm limited on space right now and then I would have to either scrap or sell the donor vehicle cheap. My experience with these Pre-Magnum V6 engines is with higher mileage the engine the timing chain probably should be replaced since there wasn't a guide until the Magnum engines. The other part is the pan would have to come for gaskets and to make sure none of the old cork gaskets made their way to the oil pan. From what I was able to verify, the horn works, the buzzer works, fuel system works, and need to verify the other stuff. The A/C stuff looks newer, tires are dated coded from 2014 and 2015, and the radiator is a newer cheap unit but, I would replace that anyways. I need to see what repair receipts it might have. Last registered in California in 2016 and towed from their to near Spokane, Washington.
[Re: TJP]
#3188877
11/05/23 11:17 AM
11/05/23 11:17 AM
Posts: 4,781 Holland MI Ottawa
2boltmain
Holland MI Ottawa
While I have never purchased a remanufactured engine I have a thought. Summit and Jegs generally have good return policies. Maybe consider a remanufactured OEM type engine thru them. I believe they both sell ATK. Regardless of name brand read and adhere to their fine print. For example- for warranty compliance on modern type (modern meaning fuel injection- plastic aluminum radiator era) remanufactured engines the owner must replace the radiator and replace-or clean the intake manifold or any passageways that coolant flows thru. This is so a plugged existing radiator or other doesn't create an overheat condition destroying the new unit. In this case- the warranty claim will be denied due to the re use of substandard components.
Keep old mopars alive.
