Page 1 of 3 1 2 3
Car turns over (starts) only in N, not Park #3186670
10/26/23 02:31 PM
10/26/23 02:31 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
I've lived with it, but I know this isn't "correct" in terms of standard 727 functionality. Suggestions, appreciated! Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Car turns over (starts) only in N, not Park [Re: Brad_Haak] #3186673
10/26/23 02:40 PM
10/26/23 02:40 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Time to adjust the NSS?
Re: Car turns over (starts) only in N, not Park [Re: Brad_Haak] #3186674
10/26/23 02:40 PM
10/26/23 02:40 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Linkage/cable slightly out of adjustment is where I'd start.
Re: Car turns over (starts) only in N, not Park [Re: slantzilla] #3186677
10/26/23 03:06 PM
10/26/23 03:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree Check for worn/missing plastic bushings in the shift linkage.
Re: Car turns over (starts) only in N, not Park [Re: Brad_Haak] #3186681
10/26/23 03:14 PM
10/26/23 03:14 PM
Great White North
W
Wheeler Offline
Wheeler  Offline
W
Great White North
Bad neutral safety switch?
Re: Car turns over (starts) only in N, not Park [Re: John_Kunkel] #3186705
10/26/23 07:17 PM
10/26/23 07:17 PM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
This is probably the case. As a side note, I remember my uncle always had Fords as I was growing up in the 60's. It was standard procedure to sit behind the wheel, reach over and pull up on the shifter with your left hand, and turn the key with the right.
Re: Car turns over (starts) only in N, not Park [Re: BTBelvedere] #3186708
10/26/23 07:56 PM
10/26/23 07:56 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Bad neutral safety switch.
Re: Car turns over (starts) only in N, not Park [Re: fastmark] #3186709
10/26/23 08:37 PM
10/26/23 08:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Shift linkage adjustment. Park is touchier than neutral.
Re: Car turns over (starts) only in N, not Park [Re: stumpy] #3186724
10/26/23 09:47 PM
10/26/23 09:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The linkage can easily be verified by disconnecting it and putting the trans lever in Park. If it magically cranks look at the bushings / linkage adjustment. If it doesn't you may have a mismatched NSS or broken rooster comb twocents beer
Re: Car turns over (starts) only in N, not Park [Re: Brad_Haak] #3186740
10/26/23 10:59 PM
10/26/23 10:59 PM
AndyF Offline
AndyF  Offline
That failure tree has several branches. Could be a bad neutral start switch, missing switch, wiring failure, internal failure inside the transmission, etc.
A visual check is the first thing. See if the wiring is hooked up, is the switch installed, etc. You can check the switch for operation with a voltmeter. If the switch isn't working it could be a bad switch or it could be a busted rooster comb. Might need to pull the pan off the transmission if the string of clues leads you there.
Re: Car turns over (starts) only in N, not Park [Re: AndyF] #3186743
10/26/23 11:06 PM
10/26/23 11:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If it starts in Neutral, the wiring and switch would have to be OK beer
Re: Car turns over (starts) only in N, not Park [Re: stumpy] #3186753
10/27/23 01:10 AM
10/27/23 01:10 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
That’s usually the case.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Car turns over (starts) only in N, not Park [Re: BloFish] #3186796
10/27/23 11:27 AM
10/27/23 11:27 AM
Loudoun County, VA
Loudoun County, VA
Linkage has new bushings and has been adjusted for clean engagement from P to 1... thinking it's the NSS now. Thx
Re: Car turns over (starts) only in N, not Park [Re: Brad_Haak] #3186826
10/27/23 12:42 PM
10/27/23 12:42 PM
moparx Offline
moparx  Offline
all the NSS does is complete the ground circuit to the starter relay, allowing the relay to energize the starter circuit.
if it starts in neutral but not in park, the switch is good.
that leaves only the linkage adjustment or the rooster comb as problem areas to address.
the NSS may need to be tightened a little more, or the wiring inspected to be sure the shift linkage is not inadvertently "moving" the plug a little. that tidbit cost me more than a few hairs to be lost before discovering that.
beer
Re: Car turns over (starts) only in N, not Park [Re: TJP] #3186830
10/27/23 12:58 PM
10/27/23 12:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, the pic below shows the contact points that ground the switch, Park is the top arrow and Neutral is the bottom arrow. If it starts in Neutral but not Park, the linkage is preventing the roostercomb from traveling far enough to make contact.
Re: Car turns over (starts) only in N, not Park [Re: moparx] #3186841
10/27/23 01:43 PM
10/27/23 01:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
t[u]hat leaves only the linkage adjustment or the rooster comb as problem areas to address.[/u]
beer
iagree With what he and others are saying
The switch doesn't know or care what position the shifter is in only that the contact point is depressed or touching the rooster comb to ground the signal wire. There are different rooster combs as well.
tightening the switch as MOPARX suggested and if possible may do the trick. The attached pic is a generic 727 valve Body but shows the two points that ground / depress the contact.
Second pic is of a 3 pin NSS with the center pin being the contact point.
beer
Re: Car turns over (starts) only in N, not Park [Re: TJP] #3186900
10/27/23 06:24 PM
10/27/23 06:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Disconnect the linkage at the trans and manually put the trans lever in park and see if it starts. Real easy check.
Re: Car turns over (starts) only in N, not Park [Re: John_Kunkel] #3186925
10/27/23 09:06 PM
10/27/23 09:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You treed me with the post & pic John 🍻
Re: Car turns over (starts) only in N, not Park [Re: stumpy] #3186926
10/27/23 09:09 PM
10/27/23 09:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Suggested that earlier but🙄?????
beer
Re: Car turns over (starts) only in N, not Park [Re: Wheeler] #3187157
10/28/23 08:07 PM
10/28/23 08:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The NSS doesn't have different positions for P and N. It is simply an on/off switch that the rooster comb inside the trans actuates.
Page 1 of 3 1 2 3
