1977 Cordoba Chronometer #3186712
10/26/23 08:50 PM
10/26/23 08:50 PM
Tony440 Offline OP
Tony440  Offline OP
What is the easiest way to remove the Chronometer(clock) on a 1977 Cordoba? Mine stopped working and I would like to replace it. Does it get removed from under the dash? The factory service manual isn't real clear on this. Thanks Tony.
Re: 1977 Cordoba Chronometer [Re: Tony440] #3186725
10/26/23 09:48 PM
10/26/23 09:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Where is it located? Above the glove box area? Have a pic? If so, remove the plastic glove box liner and take a look.
Re: 1977 Cordoba Chronometer [Re: mopars4ever] #3186774
10/27/23 09:40 AM
10/27/23 09:40 AM
Tony440 Offline OP
Tony440  Offline OP
Yes it's just above the glove box and to the left. Thanks.
Re: 1977 Cordoba Chronometer [Re: Tony440] #3186808
10/27/23 12:01 PM
10/27/23 12:01 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Weren't most of the 76 up cars, designed so that all the dash components came out "the front' ??? . . . should be able to take the trim piece off that is around the clock, then have access to the two screws (??) that hold it onto the dash and pull it out, disconnect the electrical connector and away you go . . .
Mark
Re: 1977 Cordoba Chronometer [Re: a12rag] #3186828
10/27/23 12:47 PM
10/27/23 12:47 PM
moparx Offline
moparx  Offline
Mark
that's the way it works. depending on the vehicle, the face piece needing removed could range from the whole dash face to just a small panel.
not really that hard to do.
beer
Re: 1977 Cordoba Chronometer [Re: a12rag] #3186859
10/27/23 02:58 PM
10/27/23 02:58 PM
Tony440 Offline OP
Tony440  Offline OP
Does the wood grain trim piece just pull off? I would hate to break it by doing it wrong,
Re: 1977 Cordoba Chronometer [Re: Tony440] #3186899
10/27/23 06:22 PM
10/27/23 06:22 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I'd pull the glove box and look at it from behind.
Re: 1977 Cordoba Chronometer [Re: stumpy] #3186907
10/27/23 06:49 PM
10/27/23 06:49 PM
CrazyD Offline
CrazyD  Offline
perhaps these views may help. I don't see any trim studs protuding through backside.
Craigslist dashpad
Ebay dashpad
Re: 1977 Cordoba Chronometer [Re: stumpy] #3186914
10/27/23 07:38 PM
10/27/23 07:38 PM
Tony440 Offline OP
Tony440  Offline OP
Thanks to everyone for the replies. I'll try removing the glove compartment first and check access from there. The service manual does show the mounting screws going in from the rear.
Re: 1977 Cordoba Chronometer [Re: Tony440] #3186994
10/28/23 10:41 AM
10/28/23 10:41 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
It's been a WHILE since I've had cordobas. I've had all that apart when I did. I have a 78 fury now that has the same dash and id like to add the clock as my cordobas had.
IF I REMEMBER RIGHT I think I took a screwdriver in that metal trim piece and it popped out easily, and the clock attached with 2-3 , typical "dash screws" from the front behind that metal trim.
Member "magnumguy" would be the one on here to ask. If anyone would know it would be him
