GRRRR. No such thing as 27/28" tall front runners #3186667
10/26/23 01:59 PM
10/26/23 01:59 PM
Holland MI Ottawa
2
2boltmain Offline OP
Holland MI Ottawa
Doing a mini tubbed Pro street 95 Dakota. I really want skinnies up front. 15x4 Draglites which are readily available. I want a skinny RADIAL tire thats 27 or 28" tall. My rear tires are hoosiers- their matching front tire is neither skinny or tall. 26" tall max. MT USED to make their Sportsman SR Radial front runner in 27" and 28" heights. But those are discontinued. They make only 26" tall. In a 17 and 18" wheel they offer lots. My truck will look powerful but will have the stock 190,000 mile 318 powering it and probably for a long time. I'm not concerned with some of the negatives that pizza cutter front wheel and tire combos provides. Truck will see me going back to forth from work - running errands and cruising only. I watch facebook market place daily. I made a great offer to a guy for his MT Radials that are new - 27" tall mounted on draglites. He's thinking about it. He doesn't want to break up his set but I cant use nor do I need the rears in his set. Rant paused.
Keep old mopars alive.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: 2boltmain] #3186680
10/26/23 03:14 PM
10/26/23 03:14 PM
an8sec70cuda Offline
I think your only option may be the M/T Sportsman, but it is a bias ply. Part number 255669. Summit has them in stock.
I was looking for a radial a while back and M/T told me they had no idea when or if they'd be producing the 27-28" tall radial fronts again. They also had an ET Street front radial (3851) that's 27" tall, now it's part number 250736. Summit shows one of those in stock.
I got lucky and found a new set of the M/T SR radials (6678) for sale in the classifieds here and got them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: GRRRR. No such thing as 27/28" tall front runners [Re: an8sec70cuda] #3186691
10/26/23 04:19 PM
10/26/23 04:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
They probably quit making they because they were unsafe for street use. Too tall and narrow leads to chances of getting peeled off the rim on a hard turn. That leads to legal issues for the manufacturer.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: stumpy] #3186695
10/26/23 05:02 PM
10/26/23 05:02 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Check with your local tire shop...look for a Radial 15" VW Volkswagen tire.
A friend of mine used those on the front of his Duster,in the '90's ...
IIRC he used 15X3" Centerline front wheels, 15X8" rear. Like the"Crop Duster" used. up
Plymouth Makes It!
Re: GRRRR. No such thing as 27/28" tall front runners [Re: RoadRunnerLuva] #3186696
10/26/23 05:10 PM
10/26/23 05:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You'd probably find what you want if you went with a 17" front runner.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: RoadRunnerLuva] #3186697
10/26/23 05:11 PM
10/26/23 05:11 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mickey Thompson has the ET Street fronts now in 27x6.0-15's.
Crap, didn't realize they disco'd the S/R's.
'63 Dodge 330
11.19 @ 121 mph
Re: GRRRR. No such thing as 27/28" tall front runners [Re: an8sec70cuda] #3186698
10/26/23 05:23 PM
10/26/23 05:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
All this is new to me as we run those, too, and really liked them! mad
I wonder if it has anything to do with Goodyear buying them?
'63 Dodge 330
11.19 @ 121 mph
Re: GRRRR. No such thing as 27/28" tall front runners [Re: GY3] #3186702
10/26/23 06:06 PM
10/26/23 06:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Coker Tire has some oddball stuff that is tall and skinny. 4" wide rim is a tough one. A 5" or 6' rim would be way easier.
More on there than this one that I picked as an example. Pie crust sidewall might not be ideal for a newer Dakota.
https://www.cokertire.com/tires/american-classic-670r15-blackwall.html
Just looked and Weld wheel prices are to the moon and gone. eek For that kinda money I'd buy something more upscale like something from this place. https://www.etmags.com/index.cfm
Re: GRRRR. No such thing as 27/28" tall front runners [Re: GY3] #3186704
10/26/23 06:40 PM
10/26/23 06:40 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
They have disco'ed a bunch of 15" sizes. the 26x10 and 26x12 I've used are gone. Looks like they are going after the street rod and pro street guys like Hoosier D.O.T. radial series
FWIW, Coker does offer several 27-28 inch tall radials with 6.5" section width, 4.5" tread. These are their American Classic series that are built to look like old bias plys and the cheapest one is $314 each.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: 2boltmain] #3186780
10/27/23 09:59 AM
10/27/23 09:59 AM
K
Kiddart Offline
Kiddart  Offline
K
I have heard but don't know how true it is...but some grudge guys use a motorcycle tire on their front runners.
I have never looked into it
Thank you
Kiddart
Re: GRRRR. No such thing as 27/28" tall front runners [Re: Kiddart] #3186807
10/27/23 11:59 AM
10/27/23 11:59 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
A friend just bought a nova drag car that has motorcycle tires on the front. Don’t know if II would trust them due to the load rating.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: RoadRunnerLuva] #3186816
10/27/23 12:23 PM
10/27/23 12:23 PM
Holland MI Ottawa
2
Holland MI Ottawa
I did look into this but the tallest tire seems to be 26" tall. The dakota has lots of room up front and the stock tire is 27.5" tall.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: Dabee] #3186817
10/27/23 12:25 PM
10/27/23 12:25 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I know these aren't a drag race type front runner, but I have Hancook Optimo tires on my 'Cuda, size is 205/75-15, roughly 28" tall, mounted a 4" wide Weld wheel, they are a radial, my car is over 3800lbs with me in it, runs mid-to high 10's, is street driven mostly, due to lack of tracks and time, so I have a few thousand miles on these so far, no issues.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: Neil] #3186821
10/27/23 12:30 PM
10/27/23 12:30 PM
Holland MI Ottawa
2
Holland MI Ottawa
Thank you I saved that to my favorites. I had looked on Cokers site but evidently not good enough. That price is high but everything in this hobby is expensive. I hope I can strike a deal with an on the fence seller I found on Market Place. He has 15x4 draglites with brand new 27" tall SR Sportsmans but he doesn't want to break up the 4 piece set. I only need the fronts.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: Stanton] #3186822
10/27/23 12:34 PM
10/27/23 12:34 PM
Holland MI Ottawa
2
Holland MI Ottawa
[quote=Stanton]You'd probably find what you want if you went with a 17" front runner. [/quo
Yes in 17" and 18" wheel size EVERYTHING is available. But I am true die hard 15" wheel with meaty sidewall tire kind of guy when it comes to the hobby. I miss the old days- ordering some Formula 1 Superstock N 50s from and ad in the magazines. $68 each!!!
Re: GRRRR. No such thing as 27/28" tall front runners [Re: 2boltmain] #3187021
10/28/23 12:55 PM
10/28/23 12:55 PM
central il.
second 70 Offline
second 70  Offline
central il.
Too bad you don't live closer I'd make you a heck of a deal on a set of 28" sportsman. I hate them.
Re: GRRRR. No such thing as 27/28" tall front runners [Re: 2boltmain] #3187035
10/28/23 01:41 PM
10/28/23 01:41 PM
moparx Offline
moparx  Offline
back in the day, i was the first guy to run Formula 1 Super Stock tires around here. the local mom-n-pop tire store could get them, and they were cheaper than the magazine adds.
beer
Re: GRRRR. No such thing as 27/28" tall front runners [Re: moparx] #3187066
10/28/23 02:44 PM
10/28/23 02:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Goodyear D1966, Hoosier 18112, M/T 3002
Re: GRRRR. No such thing as 27/28" tall front runners [Re: 2boltmain] #3187192
10/28/23 09:21 PM
10/28/23 09:21 PM
Holland MI Ottawa
2
Holland MI Ottawa
Ok time to put my $$ where my mouth is. Got a notification on October 27 that the 28" tall skinny SR fir a 15 wheels is available again. At least a limited quantity is: https://www.summitracing.com/parts/MTT-6678?referred_from_restock=true
Re: GRRRR. No such thing as 27/28" tall front runners [Re: 2boltmain] #3187659
10/30/23 03:10 PM
10/30/23 03:10 PM
Yep, all the commonly available 165R15 "VW" tires are more like 25" tall. Even the ones that are 165-85R15...they're still short.
CHIP
