1968 reverse light switch trigger pin #3186527
10/25/23 07:46 PM
10/25/23 07:46 PM
southern california, usa
jjdirt Offline OP
jjdirt  Offline OP
Hello does anyone know if they make the plastic reverse light trigger pin on a column shift 1966-68 mopar b body p# 288321
Re: 1968 reverse light switch trigger pin [Re: jjdirt] #3186538
10/25/23 09:08 PM
10/25/23 09:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I'll do some digging and see if I can find the place where I got one for may '68 RR, This is what you're looking for right?
Re: 1968 reverse light switch trigger pin [Re: jjdirt] #3186546
10/25/23 09:54 PM
10/25/23 09:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Currently UNAVAILABLE and very surprising considering the price. Dang that's a lot of $$$ considering it looks like a USED part but listed as NOS?
https://www.moparmall.com/MoPar-p-n-2883211-Reverse-Lamp-Switch-Pin-p/801-547.htm
Before I found one at a decent price I fixed my broken original with a long thin sheet metal screw, screwed down through the center. I'll try to find some photos of that fix and post them.
Re: 1968 reverse light switch trigger pin [Re: A12] #3186549
10/25/23 10:43 PM
10/25/23 10:43 PM
GA
roadrunninMark Offline
GA
This is one of those items that someone with a 3D printer could make?
Re: 1968 reverse light switch trigger pin [Re: A12] #3186644
10/26/23 12:55 PM
10/26/23 12:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For what they're asking for the pin it would be cheaper (and more reliable) to change the roostercomb in the trans and go to a 3-pin NSS.
