Re: 360 in a 318 833od
[Re: chargers777]
#3186326
10/25/23 05:42 AM
10/25/23 05:42 AM
Posts: 5,907 ohio
ruderunner
ohio
I'd use the 318 bell, clutch and get the correct flywheel for the 360.
Angry white pureblood male
[Re: chargers777]
#3186971
10/28/23 06:23 AM
10/28/23 06:23 AM
Posts: 5,907 ohio
ruderunner
ohio
But neither has both the 435 and 833 patterns
[Re: ruderunner]
#3186983
10/28/23 09:15 AM
10/28/23 09:15 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Here is the 833/435 dual pattern bell. This is the hard to find BB bell. I've never seen a SB bell like this. As stated the 435 bell uses the 143T wheel The 833 bell uses the 130T wheel. You can find a 130T 360 wheel or McLeod make 360 balance weights for their 130T wheel.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#3187640
10/30/23 01:45 PM
10/30/23 01:45 PM
Posts: 1,160 Cruising!
QuickDodge
Cruising!
I may have been thinking of the multi-pattern bellhousing that Moparmarks posted. After thinking about it, I'm not positive the multi-pattern bellhousing I saw was for a small block. It was years ago.....so I can't say with 100% confidence which engine it fit. The guy who had the bellhousing LOVED 440 powered W350 trucks with the 435 transmission. He built several trucks with that drive train that he used for towing.
They made some bellhousings in the later 1980's that had a hydraulic clutch. Does anyone happen to recall if those were those multi-pattern?
[Re: Hugh Jorgan]
#3188570
11/03/23 07:09 PM
11/03/23 07:09 PM
Posts: 10,609 Freeport IL USA
poorboy
Freeport IL USA
I currently have a 5 speed with the hydraulic clutch. Having had mechanical clutch linkage in the past, I would say the hydro is easier on my old knee (I'm 67), but like mentioned earlier, it does have a diaphragm pressure plate. That could be a big part of the easier pedal push.
The hydro clutch seems to have a bit slower clutch engagement then the mechanical linkage used to have, but the difference only shows up when you dump the clutch or shift fast (again, that could be the pressure plate). Under normal driving conditions its very hard to detect. If you don't intend to do much "racing" it works out OK, I believe it might show up in time slips. For the occasional burn out, or rubber in 2nd, it still works OK once you get used to it Clutches seem to last a lot longer then they did when I was younger, but that probably doesn't have anything to do with the hydro / mechanical thing though.
i think maybe the biggest difference between the mechanical and the hydro is the hydro is consonant from start of pedal movement until its finished. There is little effort required to hold the pedal down at a traffic light (it about like holding your foot on the brake pedal at a stop light), and there is not that hard spot in the center of the pedal travel. The hydro seems to reduce the shock to the drive train, but that too could just be my old age.
