Dash Paint #3186176
10/24/23 02:32 PM
10/24/23 02:32 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Hi Everyone, I did a search and came up empty. What is the paint used to redo a Black 72 Demon Dash frame? is it satin? Flat? I have been told Tuxedo satin but cannot find that anywhere.
thank you
Thank you
Kiddart
Re: Dash Paint [Re: Kiddart] #3186181
10/24/23 02:50 PM
10/24/23 02:50 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
So far I see on the innerwebs:
Krylon Matt Black
John Deer Blitz Black in Matt
Dupli color Pure Matt Black
Thank you
Kiddart
Re: Dash Paint [Re: Kiddart] #3186187
10/24/23 03:05 PM
10/24/23 03:05 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
This guy took over Totally Autos paint line. They had a suede black color with a small amount of texture that looked good for dashes and steering columns at one time.
https://8774paint1.com/collections/specialty-paints-textured-argents-organisol
Re: Dash Paint [Re: Neil] #3186211
10/24/23 04:14 PM
10/24/23 04:14 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
This:
Black-Rust-Oleum-Stops-Rust-Textured-Spray-Paint-7220830-12-oz_d1e144e0-ad76-4150-b52d-1ca310cd293d.b10a98531c2934cb948a7a8b8cc95def.jpeg
Re: Dash Paint [Re: Stanton] #3186214
10/24/23 04:25 PM
10/24/23 04:25 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Contact TCP Global @ TCPglobal.com Go to the restoration shop tab....... and then the auto color library to pick your color. Message me if you need additional help.
For the correct acrylic laquer finish noted below:
Restoration Shop (AL) Acrylic Lacquer Paint System
AL is a Professional Easy-To-Use Single-Stage Gloss Paint Coating System that is Designed for Automotive Refinishing and Restoration Purposes but is also used for Guitar and Furniture Refinishing. AL provides a long-lasting lacquer finish result that can be polished to a very high gloss. For additional color depth and extra protection for a show quality finish, AL can be clear-coated with CL3245 High-Performance Lacquer Clear (Not included, but available separately).
AL has a 1 to 1 mixing ratio, 1 part AL Paint Color to 1 part of Medium or Slow Drying Thinner
The required Medium and Slow Drying Thinners are Available Separately or in Kits along with Acrylic Lacquer Paint Color.
Use LT70 Medium Thinner for 70-85° F or LT85 High Gloss Slow Thinner for 85° F and above
The correct color code for 1972 Dart = Black 9392 link
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Dash Paint [Re: Stanton] #3186215
10/24/23 04:27 PM
10/24/23 04:27 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
The textured or suede paint was used in 1970 & was gone by 71 so no need to use it on a 72 unless you want to, but it does look good. For 1972 it looks like it's a low gloss black. I'm thinking hot rod black would probably be close, out of a can.
