6 Pac Shaker Baseplate Feet Attach Bracket Location ?
#318583
05/15/09 08:37 AM
05/15/09 08:37 AM
Can someone tell me where the 440+6 pac Shaker baseplate support feet attching bracket should be welded?I have a baseplate that does not have the bracket to attach the support feet,but do have the brackets,just need to know the correct place to spot weld them.Thanks!!
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ?
#318584
05/15/09 11:54 AM
05/15/09 11:54 AM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
I don't have measurements, but this should help. PM me if you need a higher-resolution copy.
Until total honesty is on the table, we're not even talking about reality...
