6 Pac Shaker Baseplate Feet Attach Bracket Location ? #318583
05/15/09 08:37 AM
05/15/09 08:37 AM
Anonymous OP
Anonymous OP
Can someone tell me where the 440+6 pac Shaker baseplate support feet attching bracket should be welded?I have a baseplate that does not have the bracket to attach the support feet,but do have the brackets,just need to know the correct place to spot weld them.Thanks!!
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ? #318584
05/15/09 11:54 AM
05/15/09 11:54 AM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
I don't have measurements, but this should help. PM me if you need a higher-resolution copy.
Until total honesty is on the table, we're not even talking about reality...
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ? [Re: Iceman01] #318585
05/15/09 01:44 PM
05/15/09 01:44 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Courtesy of mccannix.
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ? [Re: Snoopy] #318586
05/15/09 02:17 PM
05/15/09 02:17 PM
MD
floyd Offline
floyd  Offline
MD
Also, the OEM ones had very small dimples to locate/help with the spot weld. I think the later over the counter NOS bases sometimes didn't have the feet but I'd guess the locating dimples were still there. They're about pencil-point size.
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ? [Re: floyd] #318587
05/15/09 02:44 PM
05/15/09 02:44 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Is anyone repro-ing the feet and hardware?
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ? [Re: rayztoy] #318588
05/15/09 03:21 PM
05/15/09 03:21 PM
Snoopy Offline
Snoopy  Offline
I got mine from Terry (mccannix).
Send him a PM and see if he still has any available.
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ? [Re: rayztoy] #318589
05/15/09 03:23 PM
05/15/09 03:23 PM
MD
floyd Offline
floyd  Offline
MD
I have 340 stuff. There are a couple sources for 440/hemi feet. Check with Terry McCann (moparts member "mccannix")
Re: 6 Pac Shaker Baseplate Feet Attach Bracket Location ? [Re: floyd] #318590
05/15/09 05:08 PM
05/15/09 05:08 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
THANK YOU GENTLEMEN!
