Re: '78 - '79 grill swap?
[Re: gss]
#3185530
10/21/23 03:22 PM
10/21/23 03:22 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
The core supports should be the same except for the headlight buck area. But you can adapt that. Be cheaper than trying to find a good two headlight support. I swapped my '81 over to '72 grill and sheetmetal, and kept the '81 support. Wiring should be ok to use, just use the headlight plugs for the hi/low beam lights.
1981 Dodge D150 360 auto
[Re: moparmarks]
#3216525
02/27/24 04:49 AM
02/27/24 04:49 AM
Posts: 1,970 ID/MT
Cheeto
ID/MT
... Adapting the round H/L buckets to the quad core support is the biggest set back. I would think finding a good '79/'80 grille will be the hardest part. I have a large shelf full of '72-'78 grilles but only 1 or 2 of the '79/'80 round headlight ones and I've been collecting them for like 30 years!
Cheeto It's not perfect. It's not correct. It's not yours!
