Edelbrock Rat Roaster RR3 426 Hemi #3184719
10/17/23 10:49 PM
10/17/23 10:49 PM
Uk
molloy426 Offline OP
Uk
I know this subject has “been round the block” a few times but here goes :-
I have a Rat Roaster RR3 single 4bbl intake for a Hemi. I understand there are better options available now but that could be said for everything. It’s a cool item and I would like to make it work.
It’s obviously tricky to run just by the fact there are not many fitted on engines but many for sale, but that said, I have read older threads that people have run them in the past with minimal issues.
Problem 1 … I understand they puddle and can backfire and explode the manifold. Fixes range from:-
1. Use epoxy or weld to fill in the puddling areas.
2. Start engine with open throttle.
3. Use a secondary ignition switch to fire the engine after turning over a few times.
4. Fit a nitrous/Blower fail safe valve to rear of manifold to avoid manifold damage.
Problem 2 … Poor low range operation.
Problem 3 … Poor fuel distribution.
Is the internal divider only for dual 4bbl in line and dual cross?
Note, I have talked with a few respected people so far and their advice and opinions are valued and probably reflect the above.
I know this is going to be challenging but is there anyone out there who has successfully run a RR3 single 4bbl with a 4500 (or other a with an adaptor plate) on the street.
What about using a EFI throttle body on RR3 or modifying the internal base for Multi-port injection … anyone played with that?
Any advice is appreciated.
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: molloy426] #3184749
10/18/23 09:07 AM
10/18/23 09:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Modifying it to be a hidden multiport injection may be the way to go ... that would eliminate the fuel puddling issue as long as there is minimum reversion when the intake valves are open ?? ... , I've seen a FAST system hidden inside a crossram.
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: JohnRR] #3184774
10/18/23 10:36 AM
10/18/23 10:36 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do the pop off valve. The one I have has a 3/4” milled plate because the first one blew lol. The bottoms are different, single has no divider 2 carbs has the divider. I’m not sure how it would work with injection since it was designed for mixing gas and air in the intake. It is a cool looking intake and was the go to back in the day. Either way you’ll have to run spacers under carbs so linkage ent hit (hood clearence)
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: cudaman1969] #3184787
10/18/23 11:09 AM
10/18/23 11:09 AM
Illinois, USA
superbee69 Offline
superbee69  Offline
Illinois, USA
Rat Roster 2 x4 in line , I have one at the machine shop right now in the beginning stage of port injecting one at this moment lots of R&D to do, but they said peace of cake .We will see
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: superbee69] #3184920
10/18/23 08:13 PM
10/18/23 08:13 PM
Uk
Uk
Please keep me up to date with this R&D, i like the sound of this.
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: cudaman1969] #3184922
10/18/23 08:18 PM
10/18/23 08:18 PM
Uk
Uk
Good point, will need kickdown linkage too. I really want to run the Chrome dome cleaner. I have an aftermarket air cleaner base i can modify and save the original. I will have to get measuring.
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: molloy426] #3184973
10/19/23 07:42 AM
10/19/23 07:42 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run a Indy 440-25 on my wedge. Similar design to a Rat Rooster. The trick to starting without launching the top is patience. Cold; Pump the throttle fully 2 times and wait 20-30 seconds. Then open the throttle 1/2 way. Crank with ignition on. Usually it will fire with-in 2 revolutions or less. Hot; crack the throttle 1/3 way and crank with ignyion on. When it's below 45 degrees through a cloth fender cover over the carbs a sa choke. Once the manifold is warmed up it really drives nice. No stuffers, baffels or dams. You can hear the motor get happy with intake heat. I have popped the top off in the past. Since using this method no issues. Car has over 950 passes with this intake.
Doug
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: dvw] #3185268
10/20/23 12:07 PM
10/20/23 12:07 PM
GA
roadrunninMark Offline
GA
Yoda says it best… scope
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: roadrunninMark] #3185287
10/20/23 01:20 PM
10/20/23 01:20 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
people in the know don’t need pics
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: cudaman1969] #3185288
10/20/23 01:30 PM
10/20/23 01:30 PM
GA
GA
The rest of us like to learn though…
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: roadrunninMark] #3185426
10/20/23 10:50 PM
10/20/23 10:50 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I saw this many years back.
Floyd Lippencott IV
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: mr_340] #3185427
10/20/23 10:52 PM
10/20/23 10:52 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Wow. work scope
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: mr_340] #3185430
10/21/23 12:37 AM
10/21/23 12:37 AM
Uk
Uk
Well, that fixes the fuel distribution problem
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: molloy426] #3185523
10/21/23 03:08 PM
10/21/23 03:08 PM
moparx Offline
moparx  Offline
that's pretty neat ! up bow
beer
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: mr_340] #3185531
10/21/23 03:40 PM
10/21/23 03:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The big question, WHY go to all that trouble
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: molloy426] #3185538
10/21/23 04:05 PM
10/21/23 04:05 PM
I think the "Rat Roaster and the other street type intakes like them suck badly down whiney
Hence why never really caught on the street or roundy round racing down scope twocents
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: cudaman1969] #3185569
10/21/23 07:38 PM
10/21/23 07:38 PM
A727Tflite Online content
A727Tflite  Online Content
Some class racing back in the 70’s required a stock cast aluminum intake. It didn’t say you couldn’t modify it inside.
Re: Edelbrock Rat Roaster RR3 426 Hemi [Re: A727Tflite] #3185809
10/22/23 10:11 PM
10/22/23 10:11 PM
Uk
Uk
The 4bbl version is a 4500 mount. Its been suggested the Holley Ultra XP will work well.
