WIW Hemi Block and heads
#3184781
10/18/23 10:50 AM
10/18/23 10:50 AM
Posts: 3,087 Michigan
A727Tflite
Trying to get an idea :
Trying to figure out what a complete engine is worth - I have ballpark values on everything else, trying to figure out going rates on block and heads.
1966 Hemi block, no exaggeration when I say it’s perfect. Never broken, no repairs, decks not whacked. At .020” over now - only needs a light hone. 1966 casting date, no vin. No o ring grooves, no pan rail or external/internal lightening. Basically a stock block, equalized decks, deburred.
Again, perfect set of iron heads, lightly tootsie-rolled in the ports, std. valve sizes.
Bronzewall guides.
WIW?
Re: WIW Hemi Block and heads
[Re: gtx6970]
#3184845
10/18/23 02:05 PM
10/18/23 02:05 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
[Re: gtx6970]
#3184877
10/18/23 04:21 PM
10/18/23 04:21 PM
A727Tflite
Engine has had the decks and rail machined a long time ago. I am going to raise the engine to see if the pan rail was ever stamped.
[Re: gtx6970]
#3184952
10/18/23 11:10 PM
10/18/23 11:10 PM
A727Tflite
We talking short block. Or bare block and main caps? Actually trying to determine what the whole engine is worth. The one in the picture. I have a handle on all the other parts - just wondering what an empty block is worth today, as well as good head castings. The pictured engine is complete, is an early 70’s Super Stock engine - 12.5 to 1, roller cam, etc.
[Re: gtx6970]
#3185669
10/22/23 11:05 AM
10/22/23 11:05 AM
Posts: 2,653 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Super Stock engines (even then) get decked a lot. You might want to check that. The Stage 1 Diamond crossram used to bring good money but those people are dying off now.
2011 Drag Pak Challenger
[Re: rickseeman]
#3186074
10/24/23 12:30 AM
10/24/23 12:30 AM
Posts: 4,242 State of retirement
52savoy
State of retirement
Brought back to life a thrashed junk block last year that had the wrong hands on it for a long time. Turned out stroker pistons with stock rods work perfectly on a decked block but everything else had to be machined or special made to mate up. Could write a book on how to bring one back from the brink of being junked.
