Not Mine!
https://desmoines.craigslist.org/grd/d/lacona-dodge-demon/7676056040.html1971 dodge demon.
Currently has fresh 727 no run time. 383 big block race built. Redid head gaskets and it blew them again before driving. Heads either need decked or better mls gaskets with studs. 12.5 to 1 compression. Car has new carpet, new rear axles, new 8 3/4 rear end with spool also have sure Trac for the 8 3/4 rear end. Car has disc brake conversion all the way around brand new. Brand new wheels and tires.
Have a brand new 4 link coil over conversion for the rear end also not installed yet.
For an extra $3500 have a new 440 big block re man engine. That can go with car. Swap and you're ready to go.
Car needs rust repair and body work as you can see in pictures but a super good start!
$15,000 OBO
have an original 4 speed transmission that can also go with the engine for an additional $1000
have paperwork for all new parts and work. Over 10k in New parts alone. Not including new 440 big block and original 4 speed.
