New style rockers #3184560
10/17/23 09:25 AM
10/17/23 09:25 AM
Missouri
jwb123 Offline OP
jwb123  Offline OP
Missouri
Getting ready to build a 440 engine. Been building Mopar's for a long time, and all the engines I have built before with adjustable rockers used a rocker arm with a ball adjuster and a pushrod with a cup. I am seeing a lot of rockers now for the 440's with a cup in the rocker like a chevy engine, and then they would use a chevy style pushrod. I also noticed the cup in the rocker arm style the push rod cup is pressure fed while the old ball and cup style has a squirter hole giving it splash lube. It also seems the Chevy style rocker would have a little better geometry as well as better lube. The ball style rocker makes the push rod swing through a bigger arc than a cup style. Anybody used the new style rockers on a Mopar? Stock Mopar hydraulic rockers have a cup in the rocker. Any thoughts?
Re: New style rockers [Re: jwb123] #3184565
10/17/23 09:44 AM
10/17/23 09:44 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
All I know is people using ultra high lift cams use those so they don't have to think about the cup hitting the rocker. I think they use pushrod oiling in that application. Anything I put together has under .700" lift so that's not an issue for me. And of course it's too complicated for an old geezer like me. I like the stock oiling. KISS is my motto.
2011 Drag Pak Challenger
Re: New style rockers [Re: rickseeman] #3184568
10/17/23 09:59 AM
10/17/23 09:59 AM
an8sec70cuda Offline
The chinesium $200 ebay roller rockers also use a ball-ball pushrod.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New style rockers [Re: jwb123] #3184579
10/17/23 10:56 AM
10/17/23 10:56 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Jesel Pro series rockers are available with either cup-end or ball-end adjusters
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: New style rockers [Re: Brad_Haak] #3184580
10/17/23 11:09 AM
10/17/23 11:09 AM
gregsdart Offline
gregsdart  Offline
If the price is similar, i would go with ball end pushrods, cup adjuster rockers. Thwy allow more choice, allowing a more radical lift cam and stand up to very high spring loads if they are good parts. Ppl
Re: New style rockers [Re: jwb123] #3184581
10/17/23 11:10 AM
10/17/23 11:10 AM
AndyF Offline
AndyF  Offline
Yes, sometimes engine builders switch over to ball-ball pushrods although it isn't an requirement. I've used both and there are advantages and disadvantages. My old 514 race engine used Jesel rocker arms with cups in the pushrods, but the cups had to be a special order size to fit the Jesel rocker arms.
Re: New style rockers [Re: jwb123] #3184582
10/17/23 11:18 AM
10/17/23 11:18 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Any thoughts? Your question is too general to give complete advice. If you have a bunch of valvetrain related questions and help deciding what you need then Mike at B3R is good and carries many products. Geometry is designed into a rocker regardless of the adjuster. Depending on the head, cam, RPM etc there's usually more than one choice that should work. Think of the valvetrain as a system.
Re: New style rockers [Re: jwb123] #3184688
10/17/23 07:38 PM
10/17/23 07:38 PM
Md.
carnut68 Online content
carnut68  Online Content
Md.
440 Source has released their version of the ductile iron rockers 274.99 a set.
America First!
Re: New style rockers [Re: AndyF] #3184750
10/18/23 09:10 AM
10/18/23 09:10 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The pictures of the stuff you've used/made never ceases to amaze me, who made those pushrods ?
Re: New style rockers [Re: carnut68] #3184805
10/18/23 12:22 PM
10/18/23 12:22 PM
Kirkland, Washington
Pacnorthcuda Offline
That’s very interesting!
Re: New style rockers [Re: carnut68] #3184976
10/19/23 08:01 AM
10/19/23 08:01 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Went to look at those and saw they have also "cloned" Comp's Pro Magnum bushed steel roller rockers for about $600
Re: New style rockers [Re: Brad_Haak] #3185008
10/19/23 11:13 AM
10/19/23 11:13 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
I just saw those too. They look interesting. If anyone has used them,, feedback would be appreciated. I use the comp pro magnums. I like the rocker, but the shafts are starting to wear..........
Re: New style rockers [Re: varunner] #3185161
10/19/23 09:51 PM
10/19/23 09:51 PM
gregsdart Offline
gregsdart  Offline
How expensive would it be to have rocker shafts DLC coated? Then the bushed rockers might live a lot longer?
Re: New style rockers [Re: gregsdart] #3185455
10/21/23 08:43 AM
10/21/23 08:43 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Probably not too much, $50 ea. ?? I was thinking about doing this before putting my motor back together. This might be one of those issues that I want to fix, but not necessary.
