I Have No Power From a Stop #3184236
10/15/23 07:36 PM
10/15/23 07:36 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
'69 Road Runner, freshly rebuild 383 with small Summit camshaft and 9.0 compression, electronic ignition with original heads and an Edlebrock 650. 4 speed with new Brewster's clutch and a suregrip 3.23.
When I start from a stop it seems like I have to ride the clutch to get the car to start moving, like is has no power. Once the car is moving and the clutch is all the way out it will accelerate fine and seems to have the power it should. The clutch isn't slipping, it just seems like I have no power/torque when I start letting out the clutch.
This is my only 4 speed car so I don't have much to compare it to but this can't be right. What are your thoughts???
Re: I Have No Power From a Stop [Re: VITC_GTX] #3184252
10/15/23 08:20 PM
10/15/23 08:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
are you running a stock type ignition system?
Do you know what you initial timing is set at? S/be ~ 10 degrees BTDC as a starting point wit the vacuum advance disconnected if you have it hooked up..
Are you running a vacuum advance?
If so, is it hooked up to manifold or ported vacuum. Should be ported. but some may argue that.
Also need to know what your mechanical advance is doing ad make sure it is not affecting your initial timing setting.
Any other oddities such as idle, setting mixture, surging issues ?
Re: I Have No Power From a Stop [Re: TJP] #3184258
10/15/23 08:41 PM
10/15/23 08:41 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
All good questions.
It has the Summit electronic ignition/dizzy. The timing is about 12 degrees to keep it at ~34 total. Vacuum is hooked up to ported vacuum. No other know issues.
Once it get's going it accelerates OK.
Re: I Have No Power From a Stop [Re: VITC_GTX] #3184272
10/15/23 09:50 PM
10/15/23 09:50 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
try more initial timing. If that helps, change the curve.
Re: I Have No Power From a Stop [Re: VITC_GTX] #3184279
10/15/23 10:35 PM
10/15/23 10:35 PM
Did you build the motor? If so di you degree that cam in the motor? If yes look elsewhere. If you didn't degree it and use a Cloyes timing set it may have the dor on the cam gear wrong which makes the cam retarded when you align any of the three dots on it without verifying the actual lobe separation angles on that cam in your motor twocents
I've learn that lesson more than once from three different cam grinders realcrazy rant whiney
I degree every new cam and timing set now wrench up scope twocents
Retarded cams have no bottom end and very little mid and top end power puke down whiney
Re: I Have No Power From a Stop [Re: Cab_Burge] #3184287
10/15/23 11:59 PM
10/15/23 11:59 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
TDC mark verified?
Cam degreed?
Clutch adjusted properly?
I want my fair share
Re: I Have No Power From a Stop [Re: SomeCarGuy] #3184288
10/16/23 02:19 AM
10/16/23 02:19 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I rebuilt the engine and I did degree the cam. I had to get an adjustable timing set to get it right.
TDC was verified as well.
I forgot how I did the clutch adjustment, I'll have to go out and check. I know the engagement is all the way at the top of the pedal. It doesn't slip at high rpm's like a bad clutch does.
Re: I Have No Power From a Stop [Re: B1MAXX] #3184303
10/16/23 08:32 AM
10/16/23 08:32 AM
an8sec70cuda Offline
iagree up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: I Have No Power From a Stop [Re: VITC_GTX] #3184339
10/16/23 10:12 AM
10/16/23 10:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by VITC_GTX
All good questions.
34 total , that's not enough , bring it up to 38 , listen for pinging .
Re: I Have No Power From a Stop [Re: JohnRR] #3184392
10/16/23 03:00 PM
10/16/23 03:00 PM
SomeCarGuy Offline
SomeCarGuy  Offline
All good questions.
34 is enough. Stock heads like 33-35 for max power per Mopar Action. My own experience has been 34 is what they like. Certainly that is enough timing to make good power taking off. 38 might’ve been good with old high octane gas at every station, but not these days.
Re: I Have No Power From a Stop [Re: SomeCarGuy] #3184393
10/16/23 03:09 PM
10/16/23 03:09 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You are not going to be at total timing taking off from a stop on the street, regardless of what you might set it at.
initial timing will have more effect and if the OP's numbers are correct that looks ok.
Double check you have ported vacuum to the distributor, I know you said you did, but it doesn't hurt to double check it.
Check the carb adjustments.
Maybe you need to give it more throttle when letting the clutch out? Not sure how experienced you are driving a stick car? But my 51 Plymouth, which is about 300lbs lighter and 235 hp weaker, has zero issues taking off. I do have 3.91 gears, which helps. But still, you should have more than enough poop to scoot.
Re: I Have No Power From a Stop [Re: Sniper] #3184424
10/16/23 06:30 PM
10/16/23 06:30 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I have, and have had, multiple 4 speed vehicles.
I have the oil pan and windage tray off right now fixing an oil pan leak so when I get them back on I'll re-check the timing, the ported vacuum and the clutch adjustment and then advance the initial timing to see what happens.
Re: I Have No Power From a Stop [Re: VITC_GTX] #3184440
10/16/23 07:18 PM
10/16/23 07:18 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The Road Runner is on the lift so I went out and checked the clutch linkage.
I did not have the 5/32" free play at the end of the clutch fork as recommended by the FSM, I had little to no free play. I don't think the rod was adjusted long enough to put pressure on the fingers/pressure plate that would cause any issues, but stranger things have happened.
Re: I Have No Power From a Stop [Re: VITC_GTX] #3184445
10/16/23 07:33 PM
10/16/23 07:33 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Quote
This is confusing.
Is it a steel flywheel?
Maybe increase the idle speed.
Try an initial timing of 15 degrees plus your ported vacuum advance.
Re: I Have No Power From a Stop [Re: BSB67] #3184482
10/16/23 10:34 PM
10/16/23 10:34 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Quote
This is confusing.
Sorry, this is my only 4 spd car, I do have three CJ-5's and have had 4 spd trucks but of course they are/were geared lower.
Yep, steel flywheel. I'll push the timing up a bit and see what that does for me.
Thanks.
Re: I Have No Power From a Stop [Re: VITC_GTX] #3184484
10/16/23 10:41 PM
10/16/23 10:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
based on the above statement and your previous one about the clutch engaging at the top is cause for concern eek. The clutch should start to engage about 1-1.5" or so off the floor and have free play at the top before feeling the resistance of the pressure plate. beer
Re: I Have No Power From a Stop [Re: TJP] #3184507
10/17/23 12:54 AM
10/17/23 12:54 AM
SomeCarGuy Offline
SomeCarGuy  Offline
This was my concern based on what was posted.
Re: I Have No Power From a Stop [Re: SomeCarGuy] #3184589
10/17/23 12:21 PM
10/17/23 12:21 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Well, hopefully the linkage adjustment will fix the problem!
I'm not confident that it will, but only because it's never that easy for me grin
Re: I Have No Power From a Stop [Re: VITC_GTX] #3185007
10/19/23 11:01 AM
10/19/23 11:01 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I adjusted the clutch per the FSM. That moved the clutch engagement down about an inch. It's about 4" off the floor now . That didn't do anything for the power off the line. Then I increased the accelerator pump flow, bumped up the idle from 700 to 750 and moved the timing to 19 initial (35 total), that seemed to wake it up a bit. I'm a little surprised it likes that much initial timing, it turned over a little slow when warm but I think it will be OK.
I was at 12 initial with about 29 total. I thought I was at 34 or 35 total when I last adjusted it but evidently I was wrong...
Re: I Have No Power From a Stop [Re: VITC_GTX] #3185031
10/19/23 12:28 PM
10/19/23 12:28 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
VITC_GTX
I have a 383 with a mild Mopar .474 lift cam. Timing wise, I’m running 24 initial and 36 total with one light and one medium spring to advance faster, plus vacuum advance. I believe you’re solution will be found in dialing in the timing.
Ron
