Re: 10.00 with a stroker small block [Re: dannysbee] #31831
11/01/06 04:36 PM
11/01/06 04:36 PM
NC
440Jim Offline
440Jim  Offline
NC
Although you might get it done with the Eddie SB heads, I would suggest you go one step better in the heads to be sure and run the number. Heads make the power, get some good ones.
Re: 10.00 with a stroker small block [Re: 440Jim] #31832
11/01/06 06:37 PM
11/01/06 06:37 PM
a cast stroker crank is plenty.
MP 360 shortblock..(arp rod bolts, main studs)
(just cleaned up no porting) w5 heads, flat tappet .650 cam, 13:1 #3100 72 duster and 1.45 60foot, 10.50s at 126...shifts at 7500rpm and footbraking. um yeah cast stroker crank will be plenty.
These are stock rods, hypertetnic pistons and the stock cast crank, 3 full season and haven't had any issues, won the pro championship last year 3rd this year (car is spinning due to track)
good pistons, cast crank. h-beam rods, good heads (large port commando's, w2's or 5's) good cam, converter and traction ..you're there.
Re: 10.00 with a stroker small block [Re: Brian Hafliger] #31833
11/02/06 11:22 AM
11/02/06 11:22 AM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
I know where there are at least 5 sets of race W2's, open chamber.
Where? I need another set.
[img] [/img]
Re: 10.00 with a stroker small block [Re: clonestocker] #31834
11/02/06 11:24 AM
11/02/06 11:24 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i could use A first set....
Re: 10.00 with a stroker small block #31835
11/02/06 11:50 AM
11/02/06 11:50 AM
NC
440Jim Offline
440Jim  Offline
NC
10.50s at 126... good heads (large port commando's, w2's or 5's) good cam, converter and traction ..you're there.
He wants 10.00. I agree on the good heads.
Re: 10.00 with a stroker small block [Re: dannysbee] #31836
11/02/06 12:01 PM
11/02/06 12:01 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
At that weight you wont need a bunch of engine. It amazes me that when it comes to ET everyone talks powerplants and most don't dicuss converters/clutches, tranmissions, and and gear ratios. Just as important if not more so but not as exciting to talk about.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 10.00 with a stroker small block [Re: sixpackbee] #31837
11/02/06 12:07 PM
11/02/06 12:07 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
you can't get there if you don't have a good total package, horsepower won't do you any good if you can't harness it properly.
Re: 10.00 with a stroker small block [Re: dartman366] #31838
11/02/06 01:47 PM
11/02/06 01:47 PM
Texas
dannysbee Offline OP
Texas
Ya'll get me the hp and I'll do the rest as I said this is going in a 10teen big block car. It has a 4.56 gear and I will have the 8 inch converter restalled and put all my 727 guts in a small block case. The car low 1.42-1.38 60' now at 3150. I believe the chassis has it covered.
Getting old just means you were smarter than some and luckier than others.
Re: 10.00 with a stroker small block [Re: dannysbee] #31839
11/02/06 01:57 PM
11/02/06 01:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Yep, sound's like your on it.
Re: 10.00 with a stroker small block [Re: dartman366] #31840
11/02/06 09:46 PM
11/02/06 09:46 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Interesting post to read. My dads stroker stuff is sitting at the machine shop and should debut next year. We hit 10.9's with his KB piston iron head 360 this fall. The W5 340 should be a hoot!
Re: 10.00 with a stroker small block [Re: J_BODY] #31841
11/04/06 12:01 PM
11/04/06 12:01 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
It depends on what you all ready have unless $$$ is no object. I agree E-heads are not the best and would not be my first choice. I had a new intake, headers, and H/S roller rockers off my X heads, so I was not too keen on replacing everything to go offset. You are going to pay for a good port job anyhow, so at the weight you are at you can get there with the E heads.
As far as cast cranks go, I error to the overkill side. Forged crank and R3 block here. I sleep better at night that way.
Re: 10.00 with a stroker small block [Re: weedlayer] #31842
11/27/06 11:11 AM
11/27/06 11:11 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
its just my opinion but wouldent this be great tech archive material???
THANKS!!!!
Re: 10.00 with a stroker small block [Re: DJVCuda] #31843
11/27/06 11:46 AM
11/27/06 11:46 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I have heard that for the money you will spend on mallory to balance the cast crank you may as well step up to the forged crank.
