LED light conversion #3183721
10/13/23 05:43 PM
10/13/23 05:43 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Need some help solving my turnsignals/flasher situation on my 71 GTX.
Fully rebuilt instrument cluster, new LED bulbs in dash that are dimmable & RPM limiter(almost every one of them, save for heater switch and A/G switch). New LED turnsignal, side marker, and taillights. All come on and work properly...except turn signals and flashers.
Fully rebuilt steering column with new turn signal switch, etc.
Also added LED compatible flasher (round one beside ashtray) today.
Am missing another flasher, or is it just the one on this system?
Indicator turn signal lights come on in dash, turn signal lights come on outside front and back, but no flashing.
Flashers, when turned on light up on dash...then will blink only when turn signal switch is activated, but nothing happens outside.
Re: LED light conversion [Re: cdp] #3183729
10/13/23 05:55 PM
10/13/23 05:55 PM
GA
roadrunninMark Offline
GA
I thought there were 2 flashers, one for the hazzards and one for turn signals. Also, LEDs have a polarity so you have to make sure the bulbs are wired correctly (neg to neg, pos to pos) unleass you get the one with the polarity reversing adapter. Otherwise they wont light up either.
Re: LED light conversion [Re: roadrunninMark] #3183731
10/13/23 05:58 PM
10/13/23 05:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
There are two flashers. Not a B body guy so I don't know where they are, but on my A bodies the easy one to get to is the hazard flasher, lol.
Re: LED light conversion [Re: Sniper] #3183735
10/13/23 06:12 PM
10/13/23 06:12 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Yep, found the other flasher thats about above the steering column, which I'm going back to the parts store to get another one.
On the polarity, I ~thought~ I bought the ones that it doesn't matter on polarity, as I do think they make them....but I'm not an expert. I'm assuming this would only effect the sidemarker lights though.
I checked what I ordered on Amazon and they are all non-polarity versions. And dash were all dimmable.
Re: LED light conversion [Re: cdp] #3183741
10/13/23 07:04 PM
10/13/23 07:04 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Well, installed another LED flasher, but that didn't help. So I do have one for each, the turn signal and flasher.
Re: LED light conversion [Re: cdp] #3183762
10/13/23 08:28 PM
10/13/23 08:28 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you have LED lighting in the actual turn and tail lights, they may not create enough heat to activate the flashers (I have some concerns about the LED flashers as well, nothing is as good as it was 3 years ago). There are resisters you can add to the LED turn and tail light wiring to assist the LEDs with the flasher applications. Should show up in an online search.
I have all LED lighting in my 49 Dodge pickup. I'm on my 2nd pair (turn and hazard) of LED flashers, they are only lasting about a year. The start out well, but slow down to nothing pretty quickly, even noticeable sitting at traffic lights. I'm probably going to end up adding the LED turn assist resisters to my truck.
Those turn signal flashers are bimetal switches. The contacts close when the turn switch is activated, the bimetal heats up and pulls the contact points apart until the bimetal cools and makes contact again. I believe this is done electronically these days, but how that is done is way over my head.
Re: LED light conversion [Re: Sniper] #3183767
10/13/23 08:59 PM
10/13/23 08:59 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Ebodies have 2 flashers also. One on the ashtray housing and one on the steering column bracket.
Re: LED light conversion [Re: EW1BH27] #3183770
10/13/23 09:06 PM
10/13/23 09:06 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Yes, so everything I'm reading is load resistance, which is why I bought the load resistance flasher. Now I have 2, still not working. My understanding is that I didn't need resisters at the lights. I did read on a YouTube video of converting an 80s chevy truck with both LED and standard bulbs to a Linova552, which seemed to work. The comment section, however, showed others tried with no success. One comment back was to use a load resistance flasher with a ground to solve the issue of having all LED's bulbs.
I'll look into the resisters for the bulbs, but was hoping to avoid that and not cut or add new wires to my nice originals.
Re: LED light conversion [Re: cdp] #3183813
10/14/23 01:45 AM
10/14/23 01:45 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
This is the LED flasher I used, with a ground wire, I had to switch the polarities on my plug that plugs into the flasher. The LED flasher is reverse to our Mopar wiring. Mine works fine.
Re: LED light conversion [Re: Car Nut] #3183815
10/14/23 06:15 AM
10/14/23 06:15 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
May not be the same, but should be close. I have a 70 Monte Carlo that I had issues with. The flasher I used was like the one above with the ground wire. I also bought from Superbrightleds instead of Amazon. Not sure if that made a difference.
Re: LED light conversion [Re: MI_Custumz] #3183831
10/14/23 08:46 AM
10/14/23 08:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The flashers do not need that ground wire. The polarity of them is specific - a quick and dirty bench check will show this.
Re: LED light conversion [Re: Stanton] #3183856
10/14/23 11:37 AM
10/14/23 11:37 AM
rust belt
Moparite Online content
Moparite  Online Content
rust belt
Not sure what "led flasher" you are using but get a HD flasher(used when towing a trailer) it has a timer circuit/relay and doesn't use resistance/amp load to flash the lights.
Re: LED light conversion [Re: Stanton] #3184048
10/15/23 06:32 AM
10/15/23 06:32 AM
MI_Custumz Offline
MI_Custumz  Offline
May not need it, but it's what I was looking for. The one that worked the best didn't make the clicking noise. I didn't want to be driving around with blinkers on and not know it. The one I have make 2 click noises after I turn it off, but I can live with that.
Re: LED light conversion [Re: MI_Custumz] #3185105
10/19/23 05:45 PM
10/19/23 05:45 PM
MO
cdp Offline OP
cdp  Offline OP
MO
So, found the solutions, which was stated above.
Polarity of the plug does not match the no load LED flasher. Swapped the plug and re-installed. Blinders/turn signals all now work.
