Re: Drilling concrete questions
[Re: Stanton]
#3183290
10/12/23 10:07 AM
10/12/23 10:07 AM
Posts: 10,744 North Dakota
6PakBee
North Dakota
If the SDS shank on the 3/4" bit fits your drill, it'll work. It may be slower than you are used to but it will work. The trick of double drilling a hole in concrete has never worked for me. Drill the size you want, first pass.
[Re: slantzilla]
#3183323
10/12/23 11:41 AM
10/12/23 11:41 AM
Posts: 454 PNW
Beebuzzn
PNW
With 3/4” holes and probably 12 or more if fare size pool I would invest in a rotohammer and not chance burning up your hammer drill. A cheap rotohammer from Harbor Freight or Amazon and can be had for around $100. Many also come with bits, though not very good quality but should last through a couple dozen holes if you don’t hit rebar…..Using proper tool for job will go much quicker. My HF rotohammers are 15yrs old and still working, using on a couple jobs a yr. Don’t have to worry about people stealing them also as when I had Hilti…
[Re: Beebuzzn]
#3183342
10/12/23 12:30 PM
10/12/23 12:30 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
My 30+ year old hand held Milwaukee 1/2" drill has a hammer drill option. I have drilled hundreds of holes with it over the years from 3/8" to 3/4" inch. Step up to the larger sizes as mentioned. It is not as quick to do as using an actually rotary hammer drill, but it gets the job done.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3183344
10/12/23 12:37 PM
10/12/23 12:37 PM
Posts: 5,915 ohio
ruderunner
ohio
Nobody mentioned it but, go all the way through the concrete. Drainage and getting the bolts out later are the concerns.
Angry white pureblood male
[Re: MI_Custumz]
#3183833
10/14/23 09:05 AM
10/14/23 09:05 AM
6PakBee
North Dakota
I just picked up the last one at the local HF. What grease do you use when the supplied can runs out? Also, what are the two small electrical pieces in the bag with the manual and the rubber boot in the case? 1) Grease2) Guessing they are replacement brushes.
