Re: Ring packs, gas porting, vacuum pump questions
[Re: Mbrown]
#3182966
10/11/23 07:54 AM
10/11/23 07:54 AM
Posts: 9,863 MI, usa
dvw
MI, usa
My GZ pump has required no maintenance. The motor runs .9mm stainless rings. This is the 2nd time with these style rings. They were fine before it spun a bearing breaking a rod. Currently is coming up on 200 runs. Both times there has been no degrade in performance, oil usage, smoke, or blow by that I can tell. What are they worth performance wise? Hard to tell Its always had a vaccum pump, 10-12 in/hg. all things being the same I'd say maybe .05-.10 for the rings over the .043" that were there originally. Though the .043" ran pretty well. It has alway been honed with a plate. I should add it has verticlal gas ports as well. Doug
[Re: 340Cuda]
#3183044
10/11/23 12:33 PM
10/11/23 12:33 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Smaller rings, gas ports and vacuum all will lead to more power. How much is based on the intended use of the engine and how far one takes it. On the heads up car we run .3 rings, obviously gas ports and as much vacuum as we can. But we have always done those things. The only change over the last few years has been going to smaller and smaller rings, which has led to more power and vacuum.
[Re: AndyF]
#3183094
10/11/23 02:11 PM
10/11/23 02:11 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
We run alot of 1mm, 1mm, 2mm ring packs in our higher dollar high horse power application in hundreds of engines every year. (Not cheap by any means). I still run old school 1/16, 1/16, 3/16 rings in my street / Strip 528 HEMI with a Moroso Enhanced Design 4 Vane vac pump with no issues with mine for several years now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: AndyF]
#3183236
10/11/23 09:57 PM
10/11/23 09:57 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
Thinner rings and a vacuum pump can add 50 hp to a race engine but the rest of the engine needs to be able to support another 50 hp. If you have good heads, the right cam, a good carb, etc. then sure, you should pickup some power.
If this is a dedicated race car then you might want to think about adding compression at the same time. For bracket racers I always recommend picking the CR according to the fuel that you can most easily find in your area. Usually 112 is available also everywhere so if that is the case for you then match your compression ratio to what works well with 112 and the engine should be happy for a long time. Nowhere that I have lived or raced have I ever seen 112 available except at a track, or in pails/ drums from a fuel vendor. On the other hand, 110 is readily available at the pump at a number of gas stations. Seen it available at the pump pretty commonly most everywhere. 112. Never.
[Re: B3422W5]
#3183260
10/12/23 06:47 AM
10/12/23 06:47 AM
Posts: 34 Indiana
Mbrown
Indiana
If this is a dedicated race car then you might want to think about adding compression at the same time. For bracket racers I always recommend picking the CR according to the fuel that you can most easily find in your area. Usually 112 is available also everywhere so if that is the case for you then match your compression ratio to what works well with 112 and the engine should be happy for a long time. Nowhere that I have lived or raced have I ever seen 112 available except at a track, or in pails/ drums from a fuel vendor. On the other hand, 110 is readily available at the pump at a number of gas stations. Seen it available at the pump pretty commonly most everywhere. 112. Never. Thank for all your input guys! 110 is what we normally run. It is readily available at the pump in our area. My father in law would really like to get into the 5's , but he ties my hands. I can't lighten the car at all. No rear gear change, no aftermarket block. We have been making north of 700 hp for 10 or 11 years on an oem block with no failures. I'm afraid that will change if i increase stroke or rpm range. So I am just trying to maximize what we got, within the rpm range we are currently running. I talked to him last night about a 4.5 bore block. He feels that he is too old to get his money's worth out of it.
[Re: Mbrown]
#3183341
10/12/23 12:28 PM
10/12/23 12:28 PM
Al_Alguire
Las Vegas
Maybe also start looking at the rest of the car. Maximizing all the areas may help get him there as well. Trans gearing, converter, shocks, chassis set up, lots of ways you can lighten the car that do not change its appearance, titanium and aluminum fasteners for instance. Ceramic bearings can be used in many spots on the car to improve rolling resistance, as well as aftermarketbrakes that have less or no drag. A vacuum pump and small ring pack will give you some power but its not going to be that significant. Combinng that will proper piston architecture, more compression is always a good way to make power. Combine that with a small ring pack and vaccum pump and it will ad up.
[Re: Al_Alguire]
#3183546
10/13/23 09:31 AM
10/13/23 09:31 AM
Posts: 4,074 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Maybe also start looking at the rest of the car. Maximizing all the areas may help get him there as well. Trans gearing, converter, shocks, chassis set up, lots of ways you can lighten the car that do not change its appearance, titanium and aluminum fasteners for instance. Ceramic bearings can be used in many spots on the car to improve rolling resistance, as well as aftermarketbrakes that have less or no drag. A vacuum pump and small ring pack will give you some power but its not going to be that significant. Combinng that will proper piston architecture, more compression is always a good way to make power. Combine that with a small ring pack and vaccum pump and it will ad up. Agree with all this, that's where my mind was thinking anyway. Additionally "you're" asking a lot from a stock block and you should have him consider if the stocker breaks, how much is ANOTHER rebuild going to cost (TIME/money). Doesn't seem like there's a bunch of low-hanging fruit that won't add additional stress to the block BUT, give us a break-down of the total engine combo.
[Re: HardcoreB]
#3183680
10/13/23 04:18 PM
10/13/23 04:18 PM
Posts: 34 Indiana
Mbrown
Indiana
Maybe also start looking at the rest of the car. Maximizing all the areas may help get him there as well. Trans gearing, converter, shocks, chassis set up, lots of ways you can lighten the car that do not change its appearance, titanium and aluminum fasteners for instance. Ceramic bearings can be used in many spots on the car to improve rolling resistance, as well as aftermarketbrakes that have less or no drag. A vacuum pump and small ring pack will give you some power but its not going to be that significant. Combinng that will proper piston architecture, more compression is always a good way to make power. Combine that with a small ring pack and vaccum pump and it will ad up. Agree with all this, that's where my mind was thinking anyway. Additionally "you're" asking a lot from a stock block and you should have him consider if the stocker breaks, how much is ANOTHER rebuild going to cost (TIME/money). Doesn't seem like there's a bunch of low-hanging fruit that won't add additional stress to the block BUT, give us a break-down of the total engine combo. 4.375 bore. 4.150 Eagle crank with chevy pin. Eagle rods. Srp flat top pistons, BCR caps and girdle system. Compression comes out to 12.2 The cam is a Jones solid roller. 268@ .050 intake. 276@ .050 exhaust. .465 lobe with 1.6 rockers. On a 112 lsa. IC is installed at 107 Victor max wedge heads with a ton of work in them. Super victor intake. 1050 dominator carb. I run 33 degrees timing with 110 fuel. I don't disagree with the comments about stock block. I have been scared of it for awhile. I would have to add it all up, but I bet we have close to 1000 passes on this block. The car is 3460 give or take a few pounds. Papaw has gained some weight lol. 4.10 gear 4500 stall. 28x10.5 Hoosiers. I worked on getting 60ft times down last year. Went from high 1.4's to low 1.3's. It made no difference in ET. The car mphs better with slower 60ft times. Double adjustable coilovers on front. Cal tracs with double adjustable on rear.
[Re: Mbrown]
#3183806
10/14/23 01:07 AM
10/14/23 01:07 AM
Posts: 43,249 Bend,OR USA
Cab_Burge
[Re: AndyF]
#3183820
10/14/23 07:35 AM
10/14/23 07:35 AM
Posts: 34 Indiana
Mbrown
Indiana
Get to the shop and tear it down before you make any decisions. If the block isn't cracked and the bearings all look good then I'd put a small dome on it to get the compression up to 13:1 or whatever the commonly available fuel at your track will handle. With new pistons I'd go with good rings but 4.375 isn't a super popular ring size so you kind of have to take what you can get.
Do you know what the actual stall speed is in the car? Launch stall and shift recovery stall? You usually need a data recorder or play back tach or something like that to know that number. If the stall speed going down the track is only 4500 then you could drop some time by going with a higher stall converter. With those heads and that camshaft you'll go faster if you can keep the engine in the 6000 to 7000 band all the way down the track. You are probably running 7300 or 7400 RPM at the stripe? I'm not sure where the peak power is with that combo but it could be right there in the low 7000 range. I don't know the actual launch stall or shift recovery. I have considered putting a Go Pro in the car. In the 1/4 @7200 we were on the rev limiter. I had to set the rev limiter to 7400. He doesn't really run the 1/4 any more though. Transmission specialties built the convertor for the old combo that made a little less power. We sent them the dyno sheet of this combo and they said we didn't need a new stall. Although we really don't know where peak power is. We stopped at 6500 on the dyno every pull. I set his shift rpm at 6800. Depending on the track I set his launch at 3200 or 4000. I am still working on him to build an aftermarket block.
[Re: Mbrown]
#3183867
10/14/23 12:02 PM
10/14/23 12:02 PM
Al_Alguire
Las Vegas
As I said before the overall picture is what makes or breaks a combo. Maximizing the power you do make rather than looking for more that you may or may not find. Converters are a make or break piece of the puzzle as is gearing and shocks.
[Re: Mbrown]
#3184519
10/17/23 05:12 AM
10/17/23 05:12 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Check with total seal on their ported rings. They have ports on the tops of the rings so you don't need to port the pistons, and they claim more even cylinder wear because the rings rotate so the extra pressure is not always at the same points. A bit pricy at $623.62 set for 1/16"x1/16"x3/16" AP steel. Moly are $369.92 SKU: CR9190GP 125 https://www.totalseal.com/rings/gas-ported-rings
[Re: 451Mopar]
#3184721
10/17/23 11:00 PM
10/17/23 11:00 PM
6PKRTSE
Motor City
One could go on forever to find that one extra horsepower or two. We even hot hone. We get the blocks up to operating temperature pumping hot coolant through the blocks while machining them.
