Automotive Primer Recommendation #3181480
10/05/23 07:11 PM
10/05/23 07:11 PM
Usa
A39Coronet Offline OP
Usa
What have you used for automotive body primer with good results? Everything I've used up to this point for engine and underneath has been Sherwin Williams Genesis line and their DTM sealer with good results. Moving onto the body, I believe I'd rather use a primer that can be sanded vs the epoxy sealer I have which I'm not sure would be thick enough.
Second, are the $500/gallon primers from PPG or Sherwin noticably better than cheaper stuff like TP Tools 3 in 1 at $100?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Automotive Primer Recommendation [Re: A39Coronet] #3181537
10/05/23 10:35 PM
10/05/23 10:35 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
DP 40LF ( now lead Free) PPG and Evercoat Slick Sand
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Automotive Primer Recommendation [Re: A39Coronet] #3182863
10/10/23 07:03 PM
10/10/23 07:03 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Upol 2253 is a great high build DTM primer that I've used on three cars with great results.
Re: Automotive Primer Recommendation [Re: moparpollack] #3182972
10/11/23 08:21 AM
10/11/23 08:21 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im using the DP90LV as a base direct to metal etch, then using the PPG Vibrance VP2050 high build which is also a DTM, for extra insurance. Im then going to a "Impact" brand IMP4800 2K Urethane Primer and I so far really like it. Shoots nice, wet sands GREAT! I was using a NASON brand 2 K primer, but they had a issue at a manufacturing plant and I couldnt get any activator for it, so my paint rep told me to shoot this IMPACT brand. A super high end body shop here locally uses the impact sealer and told me it is by far some of the best he has laid down.
I guess there is a lot of options out there, and the way I see it is yes the materials are crazy expensive, but in the long run when my Daughters get my cars they wont have to worry about any paint issues, or rust coming from poor prep.
Re: Automotive Primer Recommendation [Re: A39Coronet] #3183036
10/11/23 12:03 PM
10/11/23 12:03 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
For good sanding qualities, you need a surfacer.
Polyester, 2k urethane, or hybrid are your material choices in modern surfacers.
For corrosion resistance, epoxy is a very good bet direct to metal which is why many of us start with an epoxy and then apply surfacer of some kind on top of it.
On the GTX, SPI epoxy direct to metal, then SPI 2k urethane surfacer for blocking purposes.
They have a standard and a high build, I used both but preferred the standard/it sanded nicer for me.
https://www.southernpolyurethanes.com/
They treated me right. Shipping was included on everything + the tech line is the owner's cell phone.
They also have their own forum like this one with a ton of information available.
I also used their clear coat.
Years ago used pre-Valspar Matrix epoxy + 2k urethane surfacer combination before with good results, but don't know if the product is the same now.
Next project I want to try a polyester surfacer after epoxy, as I think it will help me do the job faster.
Rich H.
Esse Quam Videri
Re: Automotive Primer Recommendation [Re: ZIPPY] #3183886
10/14/23 12:37 PM
10/14/23 12:37 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
I'm with Zippy on this one. SPI products work very well and are reasonably priced
Re: Automotive Primer Recommendation [Re: RalleyA12] #3183914
10/14/23 02:31 PM
10/14/23 02:31 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
iagree
Re: Automotive Primer Recommendation [Re: forphorty] #3183995
10/14/23 08:17 PM
10/14/23 08:17 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
iagree Me 3! I've had great results from SPI epoxy primer top coated with their 2K High build.
