Re: beadlocks
[Re: dragon]
#3182976
10/11/23 08:39 AM
10/11/23 08:39 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
MacFab in NC does a great job w/ beadlock conversions. If you need rim screws, then you could use beadlocks. Especially if you're running radials...since you're not supposed to screw them to the rim.
Re: beadlocks
[Re: dragon]
#3182977
10/11/23 08:42 AM
10/11/23 08:42 AM
Posts: 2,933 A shed in England
Tig
A shed in England
We switched to beadlocks after fitting radials, using screws to locate the bead isn't recommended and after the tyre kept slipping on the rim we made the switch. Like you I couldn't see the point of a single beadlock. McFab are likely one of the companies you are thinking about but some style of wheels they are unable to convert so best to check, there is a good thread about this on Yellow Bullet. EDIT:They couldn't do my Convo pro's so I got some from Holeshot
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: beadlocks
[Re: dragon]
#3183008
10/11/23 10:51 AM
10/11/23 10:51 AM
Posts: 10,043 MN
JERICOGTX
MN
MacFab did the beadlock conversion on my M/T wheels. Zero regrets. Very easy to mount tires on them now.
69 GTX
68 Road Runner
Re: beadlocks
[Re: JERICOGTX]
#3183098
10/11/23 02:26 PM
10/11/23 02:26 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I agree. I like being able to switch mine back and forth from slicks to radials right in my own garage with no need of a tire machine. I only did mine because I originally had a deal set up with Weld to do 5 pairs of Weld wheels for Dbl beadlock combined with mine, co-workers and buddies all at once, package deal kind of thing. They all wussed out, but Weld said they would still do mine for me for the original quoted price which I am already better than W.D. with them anyway, so while expensive it was still a good deal.
One thing to watch out for when doing dbl beadlocks is depending on back spacing and style of wheel the they may not clear your rear calipers unless you have Strange low profile rear calipers like I bought to clear. Or, 16" dia. wheels help clear no matter the back spacing.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: beadlocks
[Re: dragon]
#3183118
10/11/23 03:37 PM
10/11/23 03:37 PM
Posts: 4,694 Wichita
GY3
Wichita
As for when you should do it, I mark my 275 drag radials with a paint pen on the wheel and the tire and have noticed them moving quite a bit.
I probably need to invest in a pair of beadlocks.
Re: beadlocks
[Re: Tig]
#3183162
10/11/23 05:45 PM
10/11/23 05:45 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
We switched to beadlocks after fitting radials, using screws to locate the bead isn't recommended and after the tyre kept slipping on the rim we made the switch. Like you I couldn't see the point of a single beadlock. McFab are likely one of the companies you are thinking about but some style of wheels they are unable to convert so best to check, there is a good thread about this on Yellow Bullet. EDIT:They couldn't do my Convo pro's so I got some from Holeshot Wonder why they said they cant do your Convo Pros? They certainly have done them in the past. FWIW I have had Macfab do a few sets for me over the years. My current cars both have them. As for when, thats debatable for sure. Lots of cars going really fast without them for sure.
Re: beadlocks
[Re: 6PKRTSE]
#3183282
10/12/23 09:29 AM
10/12/23 09:29 AM
Posts: 4,080 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Good point! I did mine because I liked the way they looked, with that said when I have to swap to the class legal smaller tire, I'll try runing the non-beadlocked rims because they are lighter.
Re: beadlocks
[Re: Al_Alguire]
#3183291
10/12/23 10:08 AM
10/12/23 10:08 AM
Tig
A shed in England
Can't remember exactly. It was either, a back spacing issue or they were unable to weld the beadlock on because of the Convo pro "flutes". It was a 10 x 15 with 5" b/s.
Re: beadlocks
[Re: racerx]
#3183573
10/13/23 10:59 AM
10/13/23 10:59 AM
6PKRTSE
Motor City
Single beadlocks can shock the tire unequally actually causing tire shake if the makes enough power. Either do dbl or runs screws on both sides. Many have gotten away with singles over the years though.
Re: beadlocks
[Re: 6PKRTSE]
#3183577
10/13/23 11:16 AM
10/13/23 11:16 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I glue my 14-32 slicks on and have had great success(Hi-Tack). I spent the better part of four hours prepping my new slicks. 1.25 best 60 foot time for my duster.
