Re: Post engine break-in oil change
[Re: 6PAX]
#3182948
10/11/23 01:38 AM
10/11/23 01:38 AM
RapidRobert
You might Youtube this Q & read what pops up, some interesting info
[Re: DoubleD]
#3182979
10/11/23 08:44 AM
10/11/23 08:44 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Break in oil is exactly what it says - break in the engine then change it. Break in oil does not have the detergent levels of a standard race oil . It was originally designed to break in the motor on the dyno and be changed out. If you follow NASCAR engine builders - they run the engine in break in cycles on the dyno then drop the oil and replace with oil that they intend to run for actual dyno pulls. Personally I would not run a break in oil more than a couple of passes if you did not dyno the motor. I have a test stand to break in new builds. After the break in procedure is done (flat tappets), I'll let the engine run long enough to go through a few heat cycles. Then I change the oil.
[Re: an8sec70cuda]
#3183004
10/11/23 10:36 AM
10/11/23 10:36 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
I do the same as Chip.
Only exception is...or was....when the super thick gray moly paste was used (which almost nobody does anymore as that was much more a '70s and '80s thing....but some folks may be heavily influenced by old publications where it was mentioned).
If and when that stuff is used, then it is a good idea to change the filter ASAP after run in, because it was known to sometimes plug up oil filters and sometimes traces of it could be found in the lifter valley years after the initial build.
I did use it in my first 440 around 1988. A year or two later I tore the top end off to make some changes, and there was some of the gray paste still in it.
After that I stopped using it inside the engine and relegated the moly paste to other things....
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3183015
10/11/23 11:09 AM
10/11/23 11:09 AM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
This is what I have come down to doing. Bradd Penn Break-in oil with a Jomar 100% No Bypass oil filter seems to be the best combination for initial ring seating. After the engine is run in and fine tuned on the dyno, swap out the break in oil and filter, inspect filter and then fill with high quality oil and a fresh Jomar filter.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3183040
10/11/23 12:26 PM
10/11/23 12:26 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
We usually make a few pulls after initial warm up on the break in oil. As for HP have found very little between break in oil and standard engine oil. Talking 40wt break in VS 5w30. Just got off the dyno with two engines. One made no more power on regular oil than the break in oil, this was on my 1120hp Predator. The other engine my 600-13 we never swapped to regualr oil from the break in oil. The next owner can do that.
[Re: 6PAX]
#3183107
10/11/23 02:58 PM
10/11/23 02:58 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
[Re: sean1970]
#3183332
10/12/23 12:16 PM
10/12/23 12:16 PM
Al_Alguire
Las Vegas
We use straight zero weight in the heads up car...Some power there
