Re: Sweptline era full sized truck $3250 central Iowa
[Re: wmdj5]
#3182522
10/09/23 04:30 PM
10/09/23 04:30 PM
Posts: 4,693 Wichita
GY3
Wichita
It sometimes amazes me what they put those poor little 318s into! Grain trucks were geared pretty low and just lumbered along. Consider, also, that a lot of grain country is relatively flat. We had an old Ford truck with a 292, 4 speed and a 2 speed rear axle. I was pretty adept at getting a run at the 1 hill I had to climb on the way into town and downshifting without losing speed.
[Re: GY3]
#3182597
10/09/23 08:47 PM
10/09/23 08:47 PM
Posts: 43,601 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
It sometimes amazes me what they put those poor little 318s into! Grain trucks were geared pretty low and just lumbered along. Consider, also, that a lot of grain country is relatively flat. We had an old Ford truck with a 292, 4 speed and a 2 speed rear axle. I was pretty adept at getting a run at the 1 hill I had to climb on the way into town and downshifting without losing speed. Ever drive through Iowa? It ain't flat! I have problems driving my Cummins 3500 dually through there with a 44' fifth wheel! Cool to see it has electronic ignition and the two speed rear!
JB Rhinehart, Realist
A-Body's RULE!
[Re: 340SIX]
#3182750
10/10/23 01:28 PM
10/10/23 01:28 PM
Posts: 15,911 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Shouldn't that have a poly 318 if stock? Doesn't look like poly.
Facts are stubborn things.
[Re: NITROUSN]
#3182814
10/10/23 03:48 PM
10/10/23 03:48 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Shouldn't that have a poly 318 if stock? Doesn't look like poly. Its a 1973. It should of had the LA since 1967. Also factory electronic ignition which it should have. I didn't even notice the year. I saw the grille and assumed pre-1972
