Indy 440-2D #318174
05/14/09 06:56 PM
05/14/09 06:56 PM
U.S.
moparniac Offline OP
U.S.
Anyone evr run one of these completely MW ported out....and or have it modified for a dominator....
Mopar Performance
Re: Indy 440-2D [Re: moparniac] #318175
05/14/09 07:19 PM
05/14/09 07:19 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I believe either or maybe both AndyF and Streetwize have experience with that intake.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Indy 440-2D [Re: moparniac] #318176
05/14/09 08:35 PM
05/14/09 08:35 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i have four of them,mw size. 3 on 500" motors,and one for my 572. they work really well on a street car. not so much for the 572 thou,its to small. i have never seen one modified for a dominator. i dont think it would be worth it.the upper end flow would not be enough to take advantage of a dominator,imo.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Indy 440-2D [Re: moparniac] #318177
05/14/09 09:10 PM
05/14/09 09:10 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have one that has been ported and opened up to max wedge port size. Seems to work well. Here is a pic of the flow sheet for the intake.
Re: Indy 440-2D [Re: Darryls-Demon] #318178
05/14/09 11:44 PM
05/14/09 11:44 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I ported mine to MW and per Roger Helgessen's guidance went "one step beyond". My 517 runs pretty darn well and spins to 6800 with 370+ CFM heads and a Pro-systems 1000HP. I'm considereing something like an 1150 Dommy if I can get it tweaked right for street driving, I really want to see if there's anything more left inthe manifold by removing the possibility that the carb might be holding it back, I don't know of anyone whos's run a bigger carb on one than that . It's a nice peice and it fits under the stock hood, and the torque is 'off the chain' even at 5000+ RPM.
You can see Darryl's flow numbers 380-ish that pretty impressive, more than enough t omake 700HP, and on the street a dual plane with that kind of potential and broader torque/powerband might be something to consider if you don't want to run a ton of gear and stall in your combo. I think the last Indy single I worked with on a bench (several years ago) would flow about 400-410.
Darryl, what does Rogers text in RED say at the bottom?
I can't make it all out
BTW, the crank I got off you is gonna work out AWESOME!!
WIZE
In Car:
Re: Indy 440-2D [Re: Streetwize] #318179
05/14/09 11:58 PM
05/14/09 11:58 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Hey Old School, dont forget about me. i want to try that intake also, if i ever can get one used, it will be tried at the track for sure. i would try to fit a Dom on it one way or another
Re: Indy 440-2D [Re: Streetwize] #318180
05/15/09 01:24 AM
05/15/09 01:24 AM
Glendale Az
Glendale Az
Hello Bobby glad to here that the crank is working out well for you.
The text reads. ( The max wedge opening gains 20-25 cfm at the most. Runner streamlining of the inside radius are very senitive & must be perfectly smooth & of a continuoueous radius or flow seperation will result.)
My intake seems to work well, A good friend of mine told me that my .030 over 440 would be lazy with indy SRs and a max wedge port window.
Needless to say I am looking forword to taking him for a ride.
Re: Indy 440-2D [Re: Darryls-Demon] #318181
05/15/09 04:27 AM
05/15/09 04:27 AM
U.S.
U.S.
someone sell me a fully ported MW one Ill slap my dominator on it and try it out.... Im liking the hood clearance idea
Mopar Performance
Re: Indy 440-2D [Re: sixpackgut] #318182
05/15/09 08:13 AM
05/15/09 08:13 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
have not forgot,i'm still waiting for 2 mopar 337 manifolds from mancini.i'll be in touch....
Re: Indy 440-2D [Re: Old School] #318183
05/15/09 09:32 AM
05/15/09 09:32 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Darryl,
Thanks for posting that, my take is that the upper plenum needs very little work beyond the MW opening, (yuo'll notice the uppers flow better OOTB by and large), but the lower needs a lot of radius work both around the short side turns and the Plenum transitions. I actually slightly enlarged the Plenum on the lower half relative to the upper, that helps a bit as well.
When putting my combo together I really thought the 2d would be a cork with the Chap VI Maxies but with the work I did to the manifold I really don't think it's costing me much at all...of course if I ran a .700 Solid roller where I was maxing out he heads the big single would start paying off, So I'm leaving about 50-60HP on the table right now in terms of potential head flow, but that's mainly so she doesn't bust the seam welds out of my cherry 1/4 panels!!
I remember years ago seeing a 493 with -1 heads pull 686hp with a ~270-ish flat tap solid and a 4150 carb with only an OOTB port match so Up to the 700-720 range I think it's a very good piece that would make better average torque than a Single Plane.....Like I said not everybody wants to build an 80/20 Race/street 500" motor with 4.30 gears and 4500 stall where the single would work better overall....I would think the Majority of 500" builders want a more moderate gear/moderate stall motor with big fat mid-range (where you can really FEEL the extra cubes ALL OF THE TIME) so the 2D should really be strongly considered on anything that's more of a 50/50 street/race 3.50-ish geared 3200-3500 stall type build....Or as Darryl points out, it works great in the 440-470 range too.
WIZE
In Car:
Re: Indy 440-2D [Re: moparniac] #318184
05/15/09 11:21 AM
05/15/09 11:21 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Wedgie. All kidding aside , Good luck sat and be safe
