School me on Desktop Monitors PLEASE
#3181194
10/04/23 11:23 PM
10/04/23 11:23 PM
Posts: 15,372 Omaha Ne
TJP
Omaha Ne
My 22" or so monitor began flaking out so i upgraded to an Acer Nitro 31.5" FHD 1920 x 1080 1500R Curved PC Gaming Monitor | AMD FreeSync | 75Hz Refresh | 1ms VRB | VESA Mountable | Height, Tilt, Swivel Adjustable | 1 x HDMI 1.4 Port & VGA | XZ320QR. LINKY 1I found the WHITE background a bit overwhelming so switched to Dark Mode. Can't honestly remember if everything went dark or not but i was happy with it until it started randomly going blank. I suspect it may have had a flakey connection at the power supply plug So I returned it and ordered the following, PHILIPS 322E1C 32" Super-Curved Frameless Monitor, Full HD VA, 104% sRGB, Adaptive-Sync 75Hz, VESA, 4Yr Advance Replacement Warranty, Black/Silver LINKY 2I can't seem to get as comfortable with the Phillips Monitor as I was with the Acer color wise. Currently my Outlook 2019 mail looks like a 1955 television screen being a bit gray with horizontal lines. but at least it's not blinding me. I'm thinking the acer may have had more adjustments or options on the color but not 100% on that. All I want is a 32" monitor that will support the dark mode in all the programs, browsers etc. I'm not into gaming or any of that. I don't know enough about all of the technology to know what I need or don't. Any help??? I included links to the AMZ pages that have more info on the specs for each monitor. I did note the Phillips manual was printed in 2017 so maybe that has something to do with it TIA
Re: School me on Desktop Monitors PLEASE
[Re: TJP]
#3181199
10/04/23 11:35 PM
10/04/23 11:35 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I can't seem to get as comfortable with the Phillips Monitor as I was with the Acer color wise. Currently my Outlook 2019 mail looks like a 1955 television screen being a bit gray with horizontal lines. but at least it's not blinding me. I'm thinking the acer may have had more adjustments or options on the color but not 100% on that. All I want is a 32" monitor that will support the dark mode in all the programs, browsers etc. I'm not into gaming or any of that. TIA I'm not good with colors but this sounds pretty outrageous. All I can offer is you're not using the VGA input are you? I used VGA until a few years ago without much trouble until one of the 25 pins gets bent or damaged, then the colors are really really bad. If you using VGA, try a different cable. I've never had a problem with HDMI or Display Port. If you have the option of HDMI or Display Port, switch immediately.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: stumpy]
#3181348
10/05/23 01:12 PM
10/05/23 01:12 PM
TJP
Omaha Ne
What graphics card are you using? Intel UHD 630 BTW you're getting into foreign language territory with me π€£ I did just check the drivers and they are up to date. Again, I don't do anything with games etc.
[Re: 3hundred]
#3181349
10/05/23 01:13 PM
10/05/23 01:13 PM
TJP
Omaha Ne
I can't seem to get as comfortable with the Phillips Monitor as I was with the Acer color wise. Currently my Outlook 2019 mail looks like a 1955 television screen being a bit gray with horizontal lines. but at least it's not blinding me. I'm thinking the acer may have had more adjustments or options on the color but not 100% on that. All I want is a 32" monitor that will support the dark mode in all the programs, browsers etc. I'm not into gaming or any of that. TIA I'm not good with colors but this sounds pretty outrageous. All I can offer is you're not using the VGA input are you? I used VGA until a few years ago without much trouble until one of the 25 pins gets bent or damaged, then the colors are really really bad. If you using VGA, try a different cable. I've never had a problem with HDMI or Display Port. If you have the option of HDMI or Display Port, switch immediately. HDMI
[Re: TJP]
#3181391
10/05/23 03:10 PM
10/05/23 03:10 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I'm using 2 50" 4K and one 43" 4K TV's for my computers. I can see no reason I would ever again use a dedicated Computer monitor, and there is savings today as cheap as TV's are. I like never having to zoom. I don't get the :curved" part advantages, care to explain?
[Re: jcc]
#3181400
10/05/23 03:27 PM
10/05/23 03:27 PM
3hundred
Colleyville
I'm using 2 50" 4K and one 43" 4K TV's for my computers. I can see no reason I would ever again use a dedicated Computer monitor, and there is savings today as cheap as TV's are. I like never having to zoom. I don't get the :curved" part advantages, care to explain? Regardless of your view of monitors, he's got to figure out why two monitors in a row and maybe the old one were unsatisfactory. My guess is he needs a video card because the onboard video feed is dying. A longer shot is his HDMI cable may be bad, never seen a bad HDMI cable but suppose it could happen?
[Re: 3hundred]
#3181405
10/05/23 03:57 PM
10/05/23 03:57 PM
jcc
Bitopia
Understood, but simply plugging it into any suitable TV will narrow likely problem area.
[Re: jcc]
#3181409
10/05/23 04:10 PM
10/05/23 04:10 PM
Posts: 4,418 Michigan
MarkZ
Worthy
Worthy
Is your rig a desktop or a laptop? If it's a laptop are you using a docking station?
[Re: 3hundred]
#3181418
10/05/23 04:52 PM
10/05/23 04:52 PM
TJP
Omaha Ne
[quote=3hundred] Regardless of your view of monitors, he's got to figure out why two monitors in a row and maybe the old one were unsatisfactory. My guess is he needs a video card because the onboard video feed is dying. A longer shot is his HDMI cable may be bad, never seen a bad HDMI cable but suppose it could happen? [/quotTe] The original monitor was 15? years old and was losing segments on red colors in particular areas or the screen. The 1st replacement (Acer) would go totally off and then back on rapidly usually 4 or 5 times. It was very random. Playing with the power supply plug seemed to settle it down for a few day or three. So, that led to the current unit which is fine but the whites can be a bit bright o certain sites or when using certain programs while others are fine. I don't recall this issue with the Acer unit. This is way outside my wheelhouse so thought I might get some education here
[Re: TJP]
#3181424
10/05/23 05:05 PM
10/05/23 05:05 PM
3hundred
Colleyville
[quote=3hundred] Regardless of your view of monitors, he's got to figure out why two monitors in a row and maybe the old one were unsatisfactory. My guess is he needs a video card because the onboard video feed is dying. A longer shot is his HDMI cable may be bad, never seen a bad HDMI cable but suppose it could happen? [/quotTe] The original monitor was 15? years old and was losing segments on red colors in particular areas or the screen. The 1st replacement (Acer) would go totally off and then back on rapidly usually 4 or 5 times. It was very random. Playing with the power supply plug seemed to settle it down for a few day or three. So, that led to the current unit which is fine but the whites can be a bit bright o certain sites or when using certain programs while others are fine. I don't recall this issue with the Acer unit. This is way outside my wheelhouse so thought I might get some education here Like I said in my original post, I'm not good with colors. jcc's idea of hooking up a TV is a good one to try to isolate the issue. Forgot to mention this earlier, have you looked for specific drivers for your Phillips monitor? Best of luck to you.
[Re: TJP]
#3181478
10/05/23 06:56 PM
10/05/23 06:56 PM
Posts: 16,822 Between Houston & Galveston TX
SattyNoCar
I'm using 2 50" 4K and one 43" 4K TV's for my computers. I can see no reason I would ever again use a dedicated Computer monitor, and there is savings today as cheap as TV's are. I like never having to zoom. I don't get the :curved" part advantages, care to explain? Was unaware a TV could be used as a computer monitor, Not in my area of knowledge I found out totally by accident. When I moved into my apt, I bought a new 32" flat screen TV. I didn't realize until I set it up that it had a plug for a computer so it could be used as a monitor. My apt was pretty small so it was a space savings to have both in one unit. I didn't need my cheaters to see the screen when in computer mode..........
John
The dream is dead, long live the dream.......π₯
[Re: 3hundred]
#3181539
10/05/23 10:38 PM
10/05/23 10:38 PM
TJP
Omaha Ne
Best of luck to you. I did find the following Went to Philips website found a manual listed for this monitor and several others. Also had a driver file that was empty except for outdate instructions going back to windows 7 π. Wasted a bit more time looking through the manual πππ. Tried calling the support number several times and kept getting disconnected after varying amounts of time πππ Even tried selecting another option for spanish speaking, same π©. Not to impressed at this point with what used to be a reputable company Gonna try a bare bones one from wally world as this is getting old and HARD on my eyes. I've wondered if it might have something to do with the gaming aspect although the 1st replacement seemed OK Might try a TV as suggested as well. Will keep all posted and thanks for the help so far.
[Re: TJP]
#3181542
10/05/23 10:45 PM
10/05/23 10:45 PM
Posts: 9,468 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Im on windows 7 and it accepts any monitor I have plugged into it.
Silly questions but have you went through the menu on your monitor and looked at the settings?..... I use a larger monitor made for gaming and the older PC im on now cant function well on what made it a good buying point. Also had to adjust in the windows settings.
Got any kids or grand kids? This stuff is simple for them.
STOP POTATO HATE!
[Re: 3hundred]
#3181562
10/05/23 11:58 PM
10/05/23 11:58 PM
Posts: 10,212 Someplace you aren't
SomeCarGuy
Iβve got some big Samsung monitor. Was a gift from my wife. I think itβs a 4k and ii had to order some special cable to even use it. I do remember that. Itβs probably 5-6 years old and itβs definitely awesome. Thatβs all I got for ya.
I want my fair share
