Re: 440 into a '64 318 drivetrain?
[Re: dvw]
#3181298
10/05/23 10:59 AM
10/05/23 10:59 AM
Posts: 4,689 Wichita
GY3
Wichita
When you say "full size" are you referring to a B-body?
[Re: 61-63]
#3181465
10/05/23 06:16 PM
10/05/23 06:16 PM
Posts: 31,050 Oregon
AndyF
The car is a '64 Polara 500 with a 318, console floor shift and bucket seats. 1964 Polara 500 is basically a B body car, sometimes called an early B body. Most B body suspension parts will bolt on, some won't. Engine location is slightly different than later B body cars so you have to pay close attention to stuff like headers.
[Re: 61-63]
#3181490
10/05/23 07:42 PM
10/05/23 07:42 PM
Posts: 3,087 Michigan
A727Tflite
The car is a '64 Polara 500 with a 318, console floor shift and bucket seats. Find the correct steel engine brackets and you can reuse the isolators. Like DVR said, change the main case and reuse all the internals of the 727, reuse the trans crossmember and mount. Later model 67-72 exhaust manifolds fit perfectly, reuse the starter, alternator and even the converter. Would need B/RB alternator brackets, and the correct oil pan - 62-65 B/RB engines set further forward than 66 and later. If you use headers make sure you verify what you buy will fit the 62-65 chassis.
[Re: cudaman1969]
#3181528
10/05/23 10:09 PM
10/05/23 10:09 PM
Posts: 15,434 Omaha Ne
TJP
Omaha Ne
John, Did the 'full size "C barges" come with 318's? Can't recall ever seeing one that's likely be why we're ASSuming it's a B body A poly According to my limited research, 62 up the smallest was a 361
[Re: TJP]
#3181624
10/06/23 10:32 AM
10/06/23 10:32 AM
Posts: 8,298 fredericksburg,va
cudaman1969
fredericksburg,va
John, Did the 'full size "C barges" come with 318's? Can't recall ever seeing one that's likely be why we're ASSuming it's a B body [/quote] A poly [/quote] According to my limited research, 62 up the smallest was a 361 [/quote] He said 318 that’s why I said a poly. LA 318s came out in 67 I think. If he has the 361 nothing needs changing
[Re: cudaman1969]
#3181631
10/06/23 10:51 AM
10/06/23 10:51 AM
GY3
Wichita
v-8 K-frames from '63-'65 are all the same save for the Hemi K. Very easy to swap in the engine with the right brackets. A guy named William Cowger used to have the brackets and hardware for this but I've lost his information. I chose to keep the early K-frame in my car to use all stock components and make getting to the bellhousing bolts easy and maybe bolt on a crossram after I'm tired of going fast. 78030 Hedman headers work really well on this combo if you are so inclined.
[Re: cudaman1969]
#3181813
10/06/23 11:29 PM
10/06/23 11:29 PM
TJP
Omaha Ne
John, Did the 'full size "C barges" come with 318's? Can't recall ever seeing one that's likely be why we're ASSuming it's a B body A poly [/quote] According to my limited research, 62 up the smallest was a 361 [/quote] He said 318 that’s why I said a poly. LA 318s came out in 67 I think. If he has the 361 nothing needs changing [/quote] I believe the 62 up poly's were 318's Correct me if I'm wrong on that
