2002 Ram1500 Air bag light on #3180917
10/04/23 12:09 PM
10/04/23 12:09 PM
sc
tjmarcus1 Offline OP
sc
[b][/b] Scanner is saying the driver's squib circuit open. Clock spring? Horn is working
Re: 2002 Ram1500 Air bag light on [Re: tjmarcus1] #3181599
10/06/23 09:10 AM
10/06/23 09:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Most likely clock spring. You can unplug the yellow connector off the back of it and short it and see if your code changes…. That’ll show the integrity of the wiring is ok. Remove the airbag and perform the same test on that connector.
