Electric winch issues #3180794
10/03/23 11:23 PM
10/03/23 11:23 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
My Harbor Freight 9500 lb electric winch has worked fine for a couple of years. Lately it has had issues, when using it to pull a vehicle on the trailer it will work for a few seconds then stop. Each time I wait about 3-5 seconds and it will work again for a few seconds, It will pull the vehicle on the trailer but takes much longer of course. The last 5 vehicles it has done this. I checked and cleaned all the connections to no avail. Could it be one of the relay's? If so, how to test? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Electric winch issues [Re: Rhinodart] #3180801
10/03/23 11:58 PM
10/03/23 11:58 PM
Volt ohm meter set on 12 volts and test the hot leads to the relay when it stops keep testing until you find the problem.
How good are the grounds, are they possibly corroded? If so they will do the same thing. Remove them and clean the trailer frame and the ends of the grounds straps or base of the relays also scope wrench up wrench
Re: Electric winch issues [Re: Cab_Burge] #3180824
10/04/23 05:43 AM
10/04/23 05:43 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Sounds like it has a circuit breaker in it. Maybe getting weak.
Angry white pureblood male
Re: Electric winch issues [Re: ruderunner] #3180827
10/04/23 06:15 AM
10/04/23 06:15 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Or a thermal overload switch, which is similar, lol.
Re: Electric winch issues [Re: Sniper] #3180830
10/04/23 06:52 AM
10/04/23 06:52 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Rhino, had the same thing happen to my work rig. The intermittent work, then stop. Then clicks. Then fine. Repeat. We always had 2 batteries ready to go, so no issues there. When it finally refused to work by the remote, I tried power straight to the motor. It lurched a little and that was that. After exhausting testing options, we just bought a? Western? I'm not 100% sure. It was a similar build and has been working since( 2 years). When the Harbor units work, they work great.
Re: Electric winch issues [Re: moparjim79] #3180844
10/04/23 08:44 AM
10/04/23 08:44 AM
md
mopars4ever Offline
mopars4ever  Offline
md
For myself it did pay for me to buy a decent winch. Went thru 2 cheap ones until I bought a better one. Just my experience.
Re: Electric winch issues [Re: Rhinodart] #3180861
10/04/23 09:25 AM
10/04/23 09:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Does it have a circuit breaker? If your batteries are getting weak the voltage might be dropping enough to cause the amps to go up and trip the breaker, after a short time it resets. Just a thought.
68 Barracuda Formula S 340
Re: Electric winch issues [Re: mopars4ever] #3180863
10/04/23 09:25 AM
10/04/23 09:25 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Have you called them? They have a number for technical questions on that winch, 1-888-866-5797.
Re: Electric winch issues [Re: 6PakBee] #3180880
10/04/23 10:04 AM
10/04/23 10:04 AM
Rhinotruck
Rhinotruck
This is my 12th winch over the last 30 years, I know they only last so long and it doesn't seem to matter how much you pay for them. I will try the above replies and see what happens. It has a wireless remote, I have never changed the battery in that, don't if that causes intermittent issues...
A-Body's RULE!
Re: Electric winch issues [Re: Rhinodart] #3180906
10/04/23 11:41 AM
10/04/23 11:41 AM
hooziewhatsit Offline
My HF 3500lb did the same thing when I used a dead battery with it. I presume the voltage dropped enough under load that the winch cut out. Even with no weight on it, it would cut out.
Charged the battery for 10 minutes after I got back home, and it wound itself back up without issue.
Re: Electric winch issues [Re: Rhinodart] #3180908
10/04/23 11:46 AM
10/04/23 11:46 AM
moparx Offline
moparx  Offline
you may be on to something with the remote.
my wife's car was acting up with the key fob. sometimes the door locks would work, sometimes not. multiple pushes on the button usually worked, however.
changed the battery in it and all was well.
beer
Re: Electric winch issues [Re: moparx] #3180926
10/04/23 12:26 PM
10/04/23 12:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Does the winch motor get really hot ?
Only 2 winch problems I've had - and that sound you hear is me knocking on wood - is a bad connection at the handheld trigger for my trailer winch, and what I guess was water seepage into the winch motor used on my snow plow.
The plow motor went intermittent and quickly just quit - I merely replaced it, wasn't expensive.
I wrapped electrical tap around the seam of the plow winch and it's been fine since.
Re: Electric winch issues [Re: Sniper] #3181003
10/04/23 03:04 PM
10/04/23 03:04 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
Check solenoid.the usual cause
Re: Electric winch issues [Re: topside] #3181091
10/04/23 07:58 PM
10/04/23 07:58 PM
Rhinotruck
Rhinotruck
Motor does not get hot. I tried it again today and the battery was dead. Will charge the bejesus out of it this weekend and see if that helps, although I kjnow it had a good charge the last time it was doing this... work
A-Body's RULE!
Re: Electric winch issues [Re: Rhinodart] #3181120
10/04/23 08:40 PM
10/04/23 08:40 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We ran a cheap winch on our old race car trailer. Most of the problems we had with it were nearly always a battery issue. Car batteries used for running a winch often only last 2-3 years. The low voltage in the battery kicks out the resets on the winch motors.
If your winch motor is not getting hot, the problem is likely not a winch problem but a wiring or battery issue. The battery for the remote would be the 1st thing I would replace, if the sensor on the winch isn't getting the signal from the remote, its shutting off. Could be a problem with the receiving sensor as well. Then you need to have the main battery for the winch power load tested, I'm betting it fails that test, even being fully charged.
We got an extra couple years out of marine deep cycle batteries. They were designed to be heavily loaded until nearly dead, then be fully charged, over and over, but that was years ago, might not be the case anymore.
Re: Electric winch issues [Re: poorboy] #3181144
10/04/23 09:09 PM
10/04/23 09:09 PM
st.cloud fl
st.cloud fl
Also better to run 2 batteries. In parallel like a diesel starter in there lol
Re: Electric winch issues [Re: poorboy] #3181152
10/04/23 09:26 PM
10/04/23 09:26 PM
Rhinotruck
Rhinotruck
I always use Semi batteries, got them from International when I worked there. If I can't get them then I use Marine deep cycle, I have never used a car battery. It may be time to replace it again, batteries have gotten expensive since Covid... mad
A-Body's RULE!
Re: Electric winch issues [Re: Rhinodart] #3181162
10/04/23 09:50 PM
10/04/23 09:50 PM
st.cloud fl
st.cloud fl
We r lucky
Down here we can go to the u pull it pay 30 bucks a piece.look at the stickers some batteries r still in warranty
Re: Electric winch issues [Re: d-150] #3181192
10/04/23 11:10 PM
10/04/23 11:10 PM
Rhinotruck
Rhinotruck
Originally Posted by d-150
We r lucky
I can get used car batteries here for $30 also, but they are still not good enough for a 10,000 lb winch...
A-Body's RULE!
Re: Electric winch issues [Re: Rhinodart] #3181196
10/04/23 11:28 PM
10/04/23 11:28 PM
st.cloud fl
st.cloud fl
2decent fully charged and trickled will last a while . I have a 14500. I know
