440/727 towing combination
#3180598
10/03/23 02:14 PM
10/03/23 02:14 PM
Posts: 615 High Plains of South Dakota
olwhite64
Since my boy is now a racer, we need another tow rig. Going to convert my '86 D-150 (318/Auto) over to big block power to do the job. This truck will be hooked onto an open 18' steel/wood deck trailer towing a B-body 80 miles (roundtrip) to the track maybe 8-10 times a year; plus occasional trips to the local tavern with my bride.
I snagged up an '81 Dodge RV with 61,xxx miles on the odometer. 440/long-tail 727. Just doing some really basic stuff to the 440 (reseal, headers, Performer RPM intake, 600 Edelbrock, maybe a cam for towing if anyone has any ideas) as well as converting it to an 8 3/4 with 3.55's. Of course, I'll add a large auxiliary cooler to the trans (and maybe the engine oil too?).
My questions really center around the transmission.
Research tells me RV-spec tranny's should have some good stuff already (4 pinion planetary's, extra clutch, etc.).
Any recommendations on internal upgrades or just clean/freshen/replace what's already in there?
How about a shift kit?
The converter that is currently in the transmission has a large ring gear but also has a sticker on it that says "low-stall".
I suspect they used these to get these giant bread-box lumbering barges moving?
So, maybe the converter is perfect for the application?
Any other thoughts/concerns I'm not seeing?
Re: 440/727 towing combination
[Re: d-150]
#3180886
10/04/23 10:28 AM
10/04/23 10:28 AM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
I have a 74 Ramcharger that's a factory 440 truck and in the last few years I've driven it over 800 miles. It's fun, loud, all stock except for suspension with 3.54 gearing in the D60/D70 axles with 33" tires. I'm averaging 6.8mpg. If I was to build an older dodge truck to tow with, I'd use a 360 magnum block and make it a 408 stroker.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: shanker]
#3181107
10/04/23 08:22 PM
10/04/23 08:22 PM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
I have a 74 Ramcharger that's a factory 440 truck and in the last few years I've driven it over 800 miles. It's fun, loud, all stock except for suspension with 3.54 gearing in the D60/D70 axles with 33" tires. I'm averaging 6.8mpg. If I was to build an older dodge truck to tow with, I'd use a 360 magnum block and make it a 408 stroker. Those 33" tires are what is killing your mpg. It takes a lot of throttle to get them rolling. Then, has your speedo been calibrated to the big tires? So is a 408 stroker motor any more fuel efficient then a 440 with a good towing cam? I've pulled a car trailer with a factory 440, and I've pulled that same trailer with a 360 in a truck, the 360 did OK, but didn't hold a candle to the 440 truck, and both got the same gas mileage pulling that trailer (about 9mpg). I've never had a 408 Stroker, so I have no comparison between it and a 440.
[Re: olwhite64]
#3181283
10/05/23 10:11 AM
10/05/23 10:11 AM
Posts: 10,205 Someplace you aren't
SomeCarGuy
Deep trans pan. Coated headers to control heat.
I’d run a larger vacuum carb. A 600 is smaller than a lo po 440 had. A tq would be good and is what factory 440 trucks had for years. I’d want as much power as I could get when towing. Guys can do what they want, argue this all they want, but a bigger carb doesn’t kill low end like is claimed. The secondary’s will come in as needed. That’s been my experience running a big carb after a small one and the seeing the results.
I want my fair share
[Re: SomeCarGuy]
#3181466
10/05/23 06:17 PM
10/05/23 06:17 PM
Posts: 5,812 ohio
ruderunner
ohio
I'd consider swapping to an 8 lug D60 rear and upgrade the front brakes to 8 lug as well. The 440 won't have trouble moving the trailer but the bigger brakes and stiffer tires will help control things better.
Angry white pureblood male
[Re: J_BODY]
#3181604
10/06/23 09:21 AM
10/06/23 09:21 AM
Posts: 18,415 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Sounds like a lot of work for something the 318 would handle….. this ole beater made a ton of treks from Aberdeen to TVD open trailer with race car 318/727 I agree. For that little use the most I would do is install some 3.91 gears. If the trailer is set up the way it should be with brakes on both axles it will stop just fine.
[Re: J_BODY]
#3182696
10/10/23 10:42 AM
10/10/23 10:42 AM
olwhite64
Sounds like a lot of work for something the 318 would handle….. this ole beater made a ton of treks from Aberdeen to TVD open trailer with race car 318/727 Man I dig those Mirada wheels on that truck - after I swap mine to 4 1/2" BP I'll have to hunt down a set! The reason for the swap is the ol' 318 is really tired and the trans is some kind of version of a 904 - just figured since I had all the parts the swap made sense.
[Re: mgoblue9798]
#3183005
10/11/23 10:39 AM
10/11/23 10:39 AM
Posts: 34,883 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
ramp truck , close thread
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: mgoblue9798]
#3183295
10/12/23 10:13 AM
10/12/23 10:13 AM
olwhite64
Mike Jones has a grind specifically for the motorhome big block engines. It ain't cheap, but you get what you pay for. If I was to make one change other than what you have mentioned it would be the cam. The smallest lunati voodoo would be a distant second choice.
No more than you will be driving it though there is nothing wrong with keeping the oem cam if it is in good shape. Won't get quite the same power but it will be well above what the 318 was on its best day anyway.
Trans cooler and shift kit would be on my list as well. OEM low stall converter is good for this application. It will help keep the revs down and give a little better mileage since it is likely not a lock up converter.
How do I find out about Mike Jones? Did a search and the commonality of his name about put Google into a tailspin...
