Page 4 of 6 1 2 3 4 5 6
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3180525
10/03/23 10:25 AM
10/03/23 10:25 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
Not real happy with the total ring-pac but the oil ring drags at 14lbs now/close enough. Recip spinning is 20lbs with the 'top-fuel' rear main installed FWIW
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3180526
10/03/23 10:28 AM
10/03/23 10:28 AM
Shelby Twp. Mi
Shelby Twp. Mi
Swap meet GRP's needed some detailing and I polished the pins.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3180529
10/03/23 10:32 AM
10/03/23 10:32 AM
Shelby Twp. Mi
Shelby Twp. Mi
Think I mentioned TS3103 Jim gave me a thrust washer for the Jesel belt but the ID was way too big. I used it for mock-up, then I opened up my old std. washer to 55mm. (because Jesel doesnt make the washer in 55mm ID) That took a little patience to do.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3180532
10/03/23 10:36 AM
10/03/23 10:36 AM
Shelby Twp. Mi
Shelby Twp. Mi
Lastly, currently I have to disassemble the shortblock because I didnt measure crank endplay during mock-up and it's only got .003" SOAB! It's getting really hard to be motivated lately because it's so late in the season. But I still keep plugging away LATE for some reason.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3180582
10/03/23 01:37 PM
10/03/23 01:37 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Originally Posted by HardcoreB
After sorting this all, I ordered some 7/16x.168" straight-wall pushrods from Manton with .040 restrictors. I had an intake manifold flange from my buddies 1400HP single-4 565" BBC and laid on the deck-surface to gage why his makes so much more power than my 440-1's (in the background)
The old NMCA Real Street class rules used to have a weight adder determined by how raised off the deck surface the intake port floor was. Thought that was a pretty clever way of trying to even things out. Looking good!
Re: 'new' engine UPDATES 440-1cnc [Re: fbs63] #3180840
10/04/23 08:20 AM
10/04/23 08:20 AM
Shelby Twp. Mi
Shelby Twp. Mi
Thanks Bob! Yes, one of the many rules considers port floor from the deck. There's no way you could make parity by rules to make the stuff I choose to use to be 'competitive'. Last night, I got it apart then sanded .004 form the front thrust surface, the recip is back in and I have .007"!!!
Re: 'new' engine UPDATES 440-1cnc [Re: fbs63] #3180928
10/04/23 12:27 PM
10/04/23 12:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
NMCa still uses that in the rules for NA10.5. Seperates heads in to categories for weight based on distance off the deck. As well as a few other things smile
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3180935
10/04/23 12:36 PM
10/04/23 12:36 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Removed old SS .045 o-rings from deck...that was fun? Replaced with copper and filed down flush...
You are good with a file.
2011 Drag Pak Challenger
Re: 'new' engine UPDATES 440-1cnc [Re: rickseeman] #3180953
10/04/23 01:12 PM
10/04/23 01:12 PM
NC
440Jim Offline
440Jim  Offline
NC
Wow.
Lots of details and attention / care.
Re: 'new' engine UPDATES 440-1cnc [Re: 440Jim] #3180984
10/04/23 02:06 PM
10/04/23 02:06 PM
moparx Offline
moparx  Offline
lots of good machinist "inventive thoughts" used here. up bow
beer
Re: 'new' engine UPDATES 440-1cnc [Re: moparx] #3181016
10/04/23 04:09 PM
10/04/23 04:09 PM
Shelby Twp. Mi
Shelby Twp. Mi
Thanks guys! To a good number of people I'm a hillbilly when it comes to 'fixing' issues. But like I've said, more than one way to skin...I don't mind sharing the things i consider important, there are a good number of people still on this board that share and help just the same. It all just takes time. For one reason I share a cheaper way to measure and fix things for the guy that has more time than money. But there's a value in learning to do it yourself. In hindsight probably a lot of things i've done, I might've bought the better tool or part in the beginning.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3181312
10/05/23 11:43 AM
10/05/23 11:43 AM
moparx Offline
moparx  Offline
i'm guilty of spending more time and effort "inventing" something, when for a few bucks, what i'm "inventing" can be bought and my time saved. laugh2
growing up around depression era family does that to a guy.
beer
Re: 'new' engine UPDATES 440-1cnc [Re: moparx] #3182421
10/09/23 12:27 PM
10/09/23 12:27 PM
Shelby Twp. Mi
Shelby Twp. Mi
Heads are on. I noticed Cometic doesn't punch holes for the lower passages in the block so, I got out my punch kit for 12 holes. Because I have reverse cooling, I thought it was a good idea. Once everything was assembled I did a quick leak test.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3182433
10/09/23 12:54 PM
10/09/23 12:54 PM
Shelby Twp. Mi
Shelby Twp. Mi
A lot of build work done this weekend with typical unexpected works. I used to pull a stage from the valley and reused this cover so I had to cut a relief in the chinawall area when I learned I'd need the clearance.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3182443
10/09/23 01:07 PM
10/09/23 01:07 PM
Shelby Twp. Mi
Shelby Twp. Mi
A new ATI damper shifted both FEAD pulley alignments out so, that's getting some attention now. I got a little too generous with rtv on the Jesel shim pac and had to take that apart because it squeezed into the bearing! (Found it verifying assembled cam lash) New pulleys for the oil pump for 61% drive speed targeting the max recommended pump speed. Installed a AN fitting in the distributor plug hole for quick venting during warm-up. Verified assembled lifts, ICL and lash adjustment which I figure to be about .016" tighter than hot values.
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3182477
10/09/23 02:38 PM
10/09/23 02:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's crazy how clean that came out, it almost looks like the groove has been somehow welded with copper wire.
Rich H.
Esse Quam Videri
Re: 'new' engine UPDATES 440-1cnc [Re: ZIPPY] #3183307
10/12/23 10:55 AM
10/12/23 10:55 AM
Shelby Twp. Mi
Shelby Twp. Mi
Lol...patience grasshopper. Now hopefully it seals!
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3183310
10/12/23 11:01 AM
10/12/23 11:01 AM
Shelby Twp. Mi
Shelby Twp. Mi
I'm considering painting the block and heads black...
Re: 'new' engine UPDATES 440-1cnc [Re: HardcoreB] #3183322
10/12/23 11:36 AM
10/12/23 11:36 AM
Chesterfield Twp. Mi.
John Burdine Online work
John Burdine  Online Work
Looks good as is!
Re: 'new' engine UPDATES 440-1cnc [Re: John Burdine] #3183331
10/12/23 12:15 PM
10/12/23 12:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Would look better with different heads boogie
