Page 3 of 3 1 2 3
Re: rare bracket behind steering gear box on 89 Ram [Re: 4dr4x4] #31803
04/26/07 11:26 PM
04/26/07 11:26 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Why would it be loger? The bracket mounts to the inside of the frame. The other arm goes to the front cross member. The front cross member is the same for 2 and 4wd trucks except the 2wd has strut rod mounts on the bottom.
The steering box is mounted to the frame further forward on 4X4 trucks. For lifted 4X4 trucks with crossover steering the steering box gets mounted to the frame in the 2X4 location, further back on the frame rail.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: rare bracket behind steering gear box on 89 Ram [Re: Blown_Hemi] #31804
04/27/07 12:05 AM
04/27/07 12:05 AM
Winnipeg, Manitoba, Canada
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
The box on a 4x4 is mounted to a bracket that is mounted to the frame, I think the bracket is mounted in the same place as a 2wd box. I have a 78 4x4 frame out in the field. Tomorrow I'm going to take one of the brackets that I have and see if it will fit.
Re: rare bracket behind steering gear box on 89 Ram [Re: 4dr4x4] #31805
04/27/07 09:37 AM
04/27/07 09:37 AM
Blown_Hemi Offline
Blown_Hemi  Offline
No, the box/bracket is mounted further forward in 4X4 trucks. When you look at your 4X4 you will see the holes for the 2X4 mounting position further back on the frame.
Re: rare bracket behind steering gear box on 89 Ram [Re: Blown_Hemi] #31806
04/27/07 09:27 PM
04/27/07 09:27 PM
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
Well the verdict is in. The mounting holes are in the same place on both 2 and 4wd trucks. The plate that is used to mount the steering box on the 4x4 is held on with only 3 bolts and only uses 2 of the 4 holes that are used to mount the 2wd box. It is 17" from the top bolt hole to the end of the frame on both trucks. Check out the pictures. This is the 2wd.
Re: rare bracket behind steering gear box on 89 Ram [Re: 4dr4x4] #31807
04/27/07 09:29 PM
04/27/07 09:29 PM
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
4wd
Re: rare bracket behind steering gear box on 89 Ram [Re: 4dr4x4] #31808
04/27/07 09:34 PM
04/27/07 09:34 PM
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
I went the extra step and installed the bracket and the plate. On the 4wd you can only use 4 of the 5 bolts that you would use on a 2wd.
Re: rare bracket behind steering gear box on 89 Ram [Re: 4dr4x4] #31809
04/27/07 09:37 PM
04/27/07 09:37 PM
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
and one more from the outside of the frame.
Re: rare bracket behind steering gear box on 89 Ram [Re: 4dr4x4] #31810
04/27/07 11:21 PM
04/27/07 11:21 PM
Good work! That also explains why the factory parts books list this brace for both 2wd and 4wd starting in 86.
BRACKET, Frame Rail Steering Gear Reinforcement
(Not Illustrated)
4322029 1 86-88
4447405 1 89-93
4322029 actually is superceded by 4447405
I have also been told that the bracket you show in this picture ia also available in a heavier duty design that was used on the later year trucks, it's just that the frame holes have to be enlarged.
Page 3 of 3 1 2 3
