66 Barracuda Power Steering Pump Install Pics #3179683
09/30/23 08:21 PM
09/30/23 08:21 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I am helping a friend install a power steering upgrade kit on his 66 Barracuda.
Does anyone have any pics of the pump mounting brackets and how it mounts to the engine / pump? No information was provided in the kit.
I have reached out to the supplier but have not gotten any information as of yet.
Attached is a pic of the brackets that were provided with the kit.
The car has a 318 small block.
Thanks in advance for your help.
Re: 66 Barracuda Power Steering Pump Install Pics [Re: patosmith] #3179806
10/01/23 09:09 AM
10/01/23 09:09 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
A 66 didn't come with a 318. I say that because there are some differences between the original 273 and a later 318. One of them being a hole in the block the timing cover does not have and if you don't seal it you will get a coolant leak, BTDT. I was using an 87 318, FWIW.
My 65 Cuda has manual steering so I cannot help on the brackets.
I looked in my parts manual, brackets don't look like yours, but it's a poor picture so I googled it. They don't look like what you have.
Google 1966 barracuda power steering and look at the images, I can;t seem to link them directly.
Re: 66 Barracuda Power Steering Pump Install Pics [Re: Sniper] #3179818
10/01/23 10:16 AM
10/01/23 10:16 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What pump are you using?
Re: 66 Barracuda Power Steering Pump Install Pics [Re: Sniper] #3179826
10/01/23 10:36 AM
10/01/23 10:36 AM
P
P
Sniper, you are correct, the 66 didn't come with a 318. the original 273 needed replacing so a 318 was built and installed. I believe the owner said the 318 is a 1972
Thanks.
Re: 66 Barracuda Power Steering Pump Install Pics [Re: 6PakBee] #3179843
10/01/23 11:31 AM
10/01/23 11:31 AM
P
P
It is a Saginaw
Re: 66 Barracuda Power Steering Pump Install Pics [Re: patosmith] #3179898
10/01/23 02:40 PM
10/01/23 02:40 PM
CrazyD Offline
CrazyD  Offline
Rear bracket would attach to pump similar as shown below. Not an expert, but your front bracket looks like a big block Saginaw bracket (to me).
Re: 66 Barracuda Power Steering Pump Install Pics [Re: CrazyD] #3179946
10/01/23 06:11 PM
10/01/23 06:11 PM
P
P
CrazyD, I believe you are right!
I looked on Classic Industries and found both a SB and BB kit.
I think we got the rear bracket for a small block and a front bracket for a big block.
That explains a lot.
Thanks for your help!!!
