Re: Torsion Bar Installation
[Re: A12]
#3179504
09/30/23 08:24 AM
09/30/23 08:24 AM
Posts: 5,886 ohio
ruderunner
ohio
End to end doesn't matter but left and right do. The hex ends are clocked for each side. The numbers stamped should help determine which side is which.
Angry white pureblood male
[Re: A12]
#3180365
10/02/23 05:51 PM
10/02/23 05:51 PM
Posts: 294 Maryland
MoparMike1974
Maryland
The 3 digit number will be stamped on the side that goes in the crossmember. Even last digit is right side, odd is left side. 624/625 is 1964 A body w/ 273 engine. Side and front to back do matter if installing used bars as they have a memory. If they are marked L & R then someone marked them. I have never seen them marked from the factory except for the last 3 digits of the part number.
[Re: MoparMike1974]
#3180406
10/02/23 08:52 PM
10/02/23 08:52 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The 3 digit number will be stamped on the side that goes in the crossmember. Even last digit is right side, odd is left side. 624/625 is 1964 A body w/ 273 engine. Side and front to back do matter if installing used bars as they have a memory. If they are marked L & R then someone marked them. I have never seen them marked from the factory except for the last 3 digits of the part number. Many have the L and R on them. Here is some info. http://www.moparts.org/Tech/Archive/susp/7.html
[Re: NITROUSN]
#3180443
10/02/23 10:16 PM
10/02/23 10:16 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Yes numbered and have L and R on them. Put a little grease and it slides right in. Put the clips and dust covers Only problem one would have is rusted or scratched bars. If not no problems with used bars
