Re: inexpensive code reader to see if they have cleared recently
[Re: Andrewh]
#3179235
09/29/23 11:00 AM
09/29/23 11:00 AM
Posts: 20,173 Park Forest, IL
slantzilla
Park Forest, IL
Blue DriverI have this one. It can also diagnose in real time.
[Re: Andrewh]
#3179317
09/29/23 02:52 PM
09/29/23 02:52 PM
Posts: 3,880 Oregon
hooziewhatsit
I have a cheapo bluetooth adapter, and the Torque (free) app. I'm pretty sure if you try to look at some things, it will say the drive cycle isn't complete yet
[Re: Andrewh]
#3179328
09/29/23 03:08 PM
09/29/23 03:08 PM
Posts: 6,235 nowhere
Sniper
nowhere
it isn't seeing the cleared codes. I forget the term, but some thing shows not ready till after enough driving cycles or distance and that shows the codes were cleared recently or the battery was disconnected. either way, as long as I can see that, I know that a code won't trip again till after that says ready, and I know not to dig any further in that car.
so as long as any scanner will show it, then I am good, just making sure I don't have to spend a certain amount. the one above says check i/m readiness. I just want to make sure that is what I am looking for. Those are the OBD2 Readiness Monitors. Those will clear and have to be rerun before they pass. A good reader will tell you what state they are in. https://www.obdautodoctor.com/tutorials/obd-readiness-monitors-explained/
[Re: BloFish]
#3179365
09/29/23 04:42 PM
09/29/23 04:42 PM
slantzilla
Park Forest, IL
Fixed, thank you. The one I posted lets you monitor the test routine it goes through after you clear codes in real time. It will show how long it's been since codes were cleared.
[Re: Sniper]
#3179554
09/30/23 12:31 PM
09/30/23 12:31 PM
Posts: 4,943 WI
Dcuda69
WI
so as long as any scanner will show it, then I am good, just making sure I don't have to spend a certain amount. the one above says check i/m readiness. I just want to make sure that is what I am looking for. Those are the OBD2 Readiness Monitors. Those will clear and have to be rerun before they pass. A good reader will tell you what state they are in. https://www.obdautodoctor.com/tutorials/obd-readiness-monitors-explained/ Exactly. Any time codes are cleared or battery is disconnected all the monitors are reset to "not run" status. Specific criteria need to be met in order to get all the monitors to run, complete and pass/fail. Mode 6 will tell you monitor status but not all code readers will show mode 6(they should but not all do)
