Can a stock mech. fuel pump suddenly have too much pressure?
#3177888
09/24/23 07:42 PM
09/24/23 07:42 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Short - Is that even possible? I usually think of them blowing out the diaphragm or starting to loose pressure.
Long - Car has run fine for years with the same setup (71 Challenger, street build 360, parts store fuel pump, holley 670 street avenger) No issues with fuels, no vapor lock, etc. About a moth ago I started smelling raw fuel on occasion, usually after quick acceleration to deceleration (not racing, more like trying to make a light in traffic and having to slow down instead). I suspected a weak needle and seat. Got home friday and it dieseled, popped through the carb, and sent a huge cloud of fuel vapor up from all sides of the hood and out the T/A scoop. So much like smoke I reached for the extinguisher thinking I had lit my air cleaner on fire. Took off the lid and it had puked easily a 1/4 cup of fuel up into the air cleaner. So, since I had been planning to switch to a street demon anyway, with a 625 version rebuilt and ready to go I went ahead and swapped it on. Thing will NOT run right at all, mostly disturbingly it is wildly inconsistent One minute it acts starved for fuel and air, next minute its almost like an obstruction gets cleared and it takes off running fantastic, then falls on its face, dies at redlights, runs great again and then dies in my driveway with fuel vapor pouring out throat.
I'm stumped. Never had this much trouble understanding a carb issue. Vacuum leaks are admittedly a real possibility with the new carb install, and I'll probably try a new fuel pump and check for vacuum leaks with the street demon while I wait on replacement holley needle and seat assemblies in case the street avenger needs to go back on.
Really having a rough couple days in the garage this weekend.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Can a stock mech. fuel pump suddenly have too much pressure?
[Re: rickraw]
#3177903
09/24/23 08:44 PM
09/24/23 08:44 PM
Michael Ecks
Columbus, GA
Sounds like the street avenger had sticking needle & seat. If it worked fine before why not rebuild it? Do you have a good filter between the pump & carb? I actually went through the street avenger about 5 years ago, but I am ordering a pair of needle/seats as a back up plan. I've had the street avenger on it for probably close to 30 years and was never 100% in love with it. Had a heck of a time fixing the bog issue common to them. Really wanted the street demon to work as it resembles a T-quad unless you look close, and I had just rebuilt it an had it ready to bolt on. And yes, I have a factory style metal cannister filter between the pump and carb.
[Re: Michael Ecks]
#3177943
09/24/23 11:06 PM
09/24/23 11:06 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
No, I don't see how the mechanical fuel pump could suddenly increase its output pressure. The pressure is determined by the stiffness of the spring. Maybe if your fuel tank vent was plugged and somehow pressure built up in the tank, that could cause it? I would recommend putting a T fitting between the fuel pump and the carburetor and connect a gauge to it to monitor the fuel pressure while the problem is occurring.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
