8 3/4 Housing - Issue? #3177536
09/23/23 05:33 PM
09/23/23 05:33 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
Just tore down and cleaned up my 70 B-body 8 3/4 rear. The housing has this terrible welding on it, yet the inside is as it should be. Looks like the flange washed out and it was built up with terrible weld. Factory???
Re: 8 3/4 Housing - Issue? [Re: BPBP440] #3177546
09/23/23 06:53 PM
09/23/23 06:53 PM
Kirkland, Washington
Pacnorthcuda Offline
I’d run it.
Re: 8 3/4 Housing - Issue? [Re: Pacnorthcuda] #3177550
09/23/23 07:06 PM
09/23/23 07:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Should be strong enough just not a beauty pageant winner on that side. If you can't live with it you could always weld on more on top of it and file it out so it looks better, but you'd have some time into it. Even lead solder would work to hide it also so long as the high spots were taken down enough first so that it could be filed out nice and smooth.
Re: 8 3/4 Housing - Issue? [Re: BPBP440] #3177551
09/23/23 07:11 PM
09/23/23 07:11 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
All that welding on one side would get me concerned how straight the housing is if the ends have not been recently replaced using a bar/jig set-up, other than that, I'd also run it
, but I would remain curious why the weld in the first place.
Which side?
Re: 8 3/4 Housing - Issue? [Re: BPBP440] #3177613
09/23/23 10:07 PM
09/23/23 10:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
is that weld or some kind of sealer in the first pic? if it's weld they either didn't have the gas on or it was REALLY dirty. I'd at least grind that mess off. Re-weld if you like. The weld in the second pic looks much better as does the weld outside the circled area.
have you cleaned and looked at the backside with a good mirror? Strange area for a weld twocents shruggy
Re: 8 3/4 Housing - Issue? [Re: TJP] #3177618
09/23/23 10:52 PM
09/23/23 10:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Slag from stick welding was my guess.
The fact it was only partially removed is not a good indicator of proper welding habits.
Re: 8 3/4 Housing - Issue? [Re: jcc] #3177633
09/23/23 11:31 PM
09/23/23 11:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked the inside with a mirror or a pic with your phone?
Re: 8 3/4 Housing - Issue? [Re: stumpy] #3177717
09/24/23 11:02 AM
09/24/23 11:02 AM
BPBP440 Offline OP
BPBP440  Offline OP
I used a borescope to look inside this morning. There is a fine crack that follows this red line.
Re: 8 3/4 Housing - Issue? [Re: BPBP440] #3177754
09/24/23 12:33 PM
09/24/23 12:33 PM
moparx Offline
moparx  Offline
i wonder if someone in the past couldn't get the center section to come loose from the housing, so they just wailed away with a hammer and chisel until the gasket finally let go, or they discovered you need to remove the axles first ? shruggy biggrin
beer
Re: 8 3/4 Housing - Issue? [Re: moparx] #3177768
09/24/23 01:00 PM
09/24/23 01:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'd try to find another housing if your restoring or planning on driving it hard. Probably be OK for a cruiser. IF you decide on using it I'd definitely grind that mess out and have someone that knows how to weld go over it. twocents beer
Re: 8 3/4 Housing - Issue? [Re: moparx] #3177783
09/24/23 01:33 PM
09/24/23 01:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
laugh2
Re: 8 3/4 Housing - Issue? [Re: TJP] #3177995
09/25/23 09:39 AM
09/25/23 09:39 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Thats factory, I've seen plenty like that. That's where the fine leak comes from you can never seem to find. nothing wrong with the factory sending it out like that.
Re: 8 3/4 Housing - Issue? [Re: B1MAXX] #3177997
09/25/23 09:46 AM
09/25/23 09:46 AM
BPBP440 Offline OP
BPBP440  Offline OP
Interesting. It didn’t appear to have been apart before, which is why i asked if it could have been factory. Retaining clips were still holding the backing plates on, so assumed axles had not been pulled.
Re: 8 3/4 Housing - Issue? [Re: BPBP440] #3178044
09/25/23 12:21 PM
09/25/23 12:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
If it didn't leak before taking it apart don't fix what ain't broke tsk twocents
Don't worry, Be Happy up twocents
No one but you and those seeing this post will know or care about it work shruggy work
Re: 8 3/4 Housing - Issue? [Re: Cab_Burge] #3178115
09/25/23 02:42 PM
09/25/23 02:42 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Yes definitely wouldn't leave a puddle. Maybe drip every one in a blue moon.
Re: 8 3/4 Housing - Issue? [Re: B1MAXX] #3178121
09/25/23 02:51 PM
09/25/23 02:51 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Put it in a room that is pitch black and stick a flashlight inside it facing up from the backside and look for any porosity spots along the welded area..
